Home > Puma (Tdci) > puma aircon/heater controls backlight
Cheshire110
much of the heater controls, vent selector, fan strength etc has no backlight anymore.
LR want £600 as the whole panel 'must' be replaced... but not sure if theres a common fix? see many around with similar problems..
is is usually a bulb gone or wiring? Cheers, David
Post #271091 2nd Oct 2013 11:21pm
theorangebandit
If its all gone id sugest a fuse or a connection its unlikely all bulbs have blown. Im sure that you can buy a second hand one for a fraction of £mental!
Take it out and have a look around only a couple of bolts and pops forward
Post #271092 3rd Oct 2013 12:04am
Cheshire110
It's not all gone, and some of it comes on and off every so often. So I don't think it's a fuse etc, dodgy wiring is my guess but could be a bulb. Was just hoping there was an easy/common fix I suppose!
Will start with a poke around when I can Cheers, David
Post #271097 3rd Oct 2013 6:39am
22900013A
Mine used to do this sometimes, as did the light behind the hazard light button. A good thump on the top of the dashboard seems to correct it... 2011 110 USW
1973 Series III 1-Ton
1969 IIA 1-Ton
1966 IIA 88"
Post #271102 3rd Oct 2013 7:31am
This is a common fault and is most likely to be caused by bulb failure.
There are several (3, if I recall correctly) of those loathesome little capless bulbs which illuminate most of the HVAC control panel, and they are a common failure. They are not easy to get to, but the subjecty has been covered before on this forum several times.
See The definitive "how to" courteasy of Custom90Steve, also this, possibly this, and maybe this may be of interest.
I know from my own experiences that the LED replacements for this type of bulb do not work in this application - only the horrid incandescent things provide suitable lighing.
Post #271124 3rd Oct 2013 9:45am
schuee
At the moment my left hand side heat control back light keeps going off, by either turning back and forth or moving the slider next to it, it comes back on. Its probably been like that for a while, only noticed as the nights are pulling in. I will let the dealer look at it whilst its still under warranty, next time I'm across.
Post #271139 3rd Oct 2013 10:59am
Get them to replace the lot otherwise you'll get others go at a later time. Always best to replace bulbs together. No Guts, No Glory.
🇬🇧ðŸ´ó §ó ¢ó ¥ó ®ó §ó ¿ðŸ´ó §ó ¢ó ·ó ¬ó ³ó ¿ðŸ´ó §ó ¢ó ³ó £ó ´ó ¿ðŸ‡®ðŸ‡ªðŸ‡ºðŸ‡¸â›½ï¸ðŸ›¢ï¸âš™ï¸ðŸ§°ðŸ’ª
Post #271140 3rd Oct 2013 11:01am
Cheshire110
My warranty rejected it, hence trying to sort it myself but we may be moving garages soon so maybe they will be able to do a better job of convincing the warranty engineer to sort it Cheers, David
Post #271141 3rd Oct 2013 11:02am
Cheshire110
Cheers, those links look good Cheers, David
Post #271142 3rd Oct 2013 11:02am
You can do it yourself easy enough. Thumbs Up No Guts, No Glory.
Post #271151 3rd Oct 2013 11:46am
landy andy
Did you ever sort this? Is it definitely many individual bulbs, or is it a circuit board?
Half mine not working, and each whack I give I loose more Big Cry
Andy
Post #274713 18th Oct 2013 2:29am
Cheshire110
Not yet, not home ATM and it's low on my list I'm afraid... Cheers, David
Post #274721 18th Oct 2013 7:00am
there's a "how to" on the forum by custom90steve about middle dash bulb replacement ..
Post #274724 18th Oct 2013 7:08am
landy andy
Ohh, great will try a search (back in a bit, when I will ask where, because I can't find it)
Andy
Post #274725 18th Oct 2013 7:11am
Likeomg
i had the circuit board go... luckily warranty sorted me
Post #274729 18th Oct 2013 7:28am
