Home > Technical > Tilt fitting |
bob neville Member Since: 30 Apr 2009 Location: Marbella Posts: 3248 |
Hi Andy
There should be an ali channel fitted to the rear of the cab that the tilt fits in. It does stop short of either end and you will see gaps. I got mine about 90% water tight but it is tricky. Obviously can't take pictures as I have sold mine but if you post a picture of the problem area then maybe I can give you some more help. Bob 2015 Jaguar XE240 R Sport - goes like ....... !! 2013 Defender 90 CSW - sold 2009 Defender 110 Double Cab - sold 2001 TD5 90 CSW - offroad project - sold to a forum member 2011 Porsche Boxster - for the sunny days ! |
28th Sep 2013 9:37am |
Light right angle channel with a number of slots cut into one edge. These fit into the front pockets at the lower leading edge of the tilt & other edge has a number (4) of holes in it through which dzus 1/4 turn fasteners are fitted.
If you look into the holes in the tub you shouls see a spring clip running diagonally across it. [URL=] Click image to enlarge[/URL] [URL=] Click image to enlarge[/URL] Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated |
28th Sep 2013 10:36am |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5692 |
Ahh ok so I'm missing some bits. No Ali channel on mine or fixings, just got the galv angle that is part of the rear tub with the above mentioned holes in it.
best get me wallet out. Any idea of part numbers? Andy |
28th Sep 2013 12:23pm |
I would get the supplying dealer to sort it out as they should have been with the vehicle.
With the number of DC's about without the tilt there must be some for sale somewhere. When I sold mine the buyer said he was never going to fit the tilt. Edit This may help http://lrcat.com/#30/4/44838 Bob 2015 Jaguar XE240 R Sport - goes like ....... !! 2013 Defender 90 CSW - sold 2009 Defender 110 Double Cab - sold 2001 TD5 90 CSW - offroad project - sold to a forum member 2011 Porsche Boxster - for the sunny days ! |
28th Sep 2013 12:31pm |
BigRuss Member Since: 15 May 2010 Location: Norfolk Posts: 2785 |
Andy
You many want to look at getting some protective type coating just round the outer edge of the rear tub to stop the metal eyelets of the tilt subbing through the paint where the lashing hooks are. It not much of an issue, just looks scruffy when you have the tilt off. Russell 2011MY 110 XS USW Black |
28th Sep 2013 12:56pm |
Thanks bob. So I need parts 17, 18 and 19 then.
Russ, what type of protection would you recommend? Andy |
28th Sep 2013 2:12pm |
I thought you were missing part 24?
28th Sep 2013 2:44pm |
Some sort of vinyl strip that can be replaced easy as it gets scuffed Russell
28th Sep 2013 2:59pm |
Helicopter tape would work well:
http://www.3mdirect.co.uk/p-2893-3m-helico...-roll.aspx |
28th Sep 2013 3:08pm |
As SC said, cab end are parts 24 to 30.
17 to 19 are the side and rear end cleats. Bob 2015 Jaguar XE240 R Sport - goes like ....... !! 2013 Defender 90 CSW - sold 2009 Defender 110 Double Cab - sold 2001 TD5 90 CSW - offroad project - sold to a forum member 2011 Porsche Boxster - for the sunny days ! |
28th Sep 2013 4:14pm |
Yes but different diagram numbers on bobs link
But part number MTC4054 AAU2367 AYR500160 Andy Last edited by landy andy on 30th Mar 2014 9:54pm. Edited 1 time in total |
28th Sep 2013 4:17pm |
Where do part no. 24 and 28 in my diagram go?
28th Sep 2013 4:21pm |
Yep, 17 to 19 on my diagram You may need 22 and 23 as well (4 of each). These are the spring catches for the dzus fasteners.
24 and 28 you may or may not need. They were for the ropes on the non zipped version rear flap. My 2009 was one of the first with a zipped rear flap so I guess yours is zipped and well. Bob 2015 Jaguar XE240 R Sport - goes like ....... !! 2013 Defender 90 CSW - sold 2009 Defender 110 Double Cab - sold 2001 TD5 90 CSW - offroad project - sold to a forum member 2011 Porsche Boxster - for the sunny days ! |
28th Sep 2013 4:36pm |
Yes mine is a zip flap. Will get on to dealer Monday and see what he says about parts, if not I will send Duckworth's a message.
Thanks for your help lads Andy |
28th Sep 2013 5:31pm |
