Home > In Car Electronics > Amps for dummies
Tiger
Amps for dummies
Right this is what I think I want.
2x 10cm Speakers at the very back of the 110
2x 6x9 just behind the rear seats
2 13cm components with tweeters in the front
Active sub
What kind of Amp do I need?
I'm just not clear on 2 channel / 4 channel.
Can I adjust the fade with a 2 channel amp?
Post #269541 26th Sep 2013 10:09am
What RMS wattage are each item? No Guts, No Glory.
🇬🇧ðŸ´ó §ó ¢ó ¥ó ®ó §ó ¿ðŸ´ó §ó ¢ó ·ó ¬ó ³ó ¿ðŸ´ó §ó ¢ó ³ó £ó ´ó ¿ðŸ‡®ðŸ‡ªðŸ‡ºðŸ‡¸â›½ï¸ðŸ›¢ï¸âš™ï¸ðŸ§°ðŸ’ª
Post #269546 26th Sep 2013 10:27am
Tiger
This is the sort of thing
Focal 130A1 - 13cm components £99.99 (front)
Focal 690CA1 - 6'' x 9'' 2 Way Coaxial Speakers £84.59 (behind seats)
Pioneer G1022i - 10cm 190W 2-way speakers £24.95 (Very back)
Boss R1004 - 4 Channel 400W Amplifier £39.99
Post #269555 26th Sep 2013 11:15am
A 4 channel for your front and rear speakers and a 2 channel for the 6x9's No Guts, No Glory.
Post #269566 26th Sep 2013 12:11pm
mk1collector
You really don't need the 10s at the back and 6x9s behind the back seats. I'd dump the 10s and put the 6x9s right at the back and then get 13mm components up front all running off a 4 channel amp. It's also a great idea to add a sub (active is easiest) as this will make a massive difference in sound quality.
Ray
Post #269583 26th Sep 2013 2:28pm
barbel jim
Agree ^^^^ or an alternative 130 mm components front, 130mm co-axiels rear and a proper sub Whistle
Post #269598 26th Sep 2013 3:53pm
6x9's are great. I have a pair in the back of the 110 (and tweeters up in the roof by your head, and a 12" sub in the back too Laughing )
Post #269613 26th Sep 2013 4:54pm
