Home > Puma (Tdci) > New 2.2, odd noise? Or do they all do that?
Page 2 of 2 <12
Natlas
United Kingdom 2013 Defender 90 Puma 2.2 XS CSW Aintree Green
Mine makes the same noise and I also mentioned it to the dealer as I thought it was an exhaust leak. I think there is some kind of device just inside the wing that makes the noise but it does appear to be normal as everyone is saying.
Cheers, 2.2 90 XS
88" Series One
Old Norton Smile
Minerva
Post #269013 24th Sep 2013 9:03am
Happyoldgit
As has already been said its normal induction noise which is much more pronounced in the Puma compared with earlier models. When are we going to see some pics Chris? Wink Steve.
http://forums.lr4x4.com
Post #269023 24th Sep 2013 10:06am
Happyoldgit
Post #269024 24th Sep 2013 10:07am
Smurph
2012 Defender 110 Puma 2.2 SW Keswick Green
I,ve had my 2.2 for over a year. When I first got it also noticed the very loud air intake......funny thing... you get to like it after awhile!
Post #269611 26th Sep 2013 4:46pm
Hifonics
2013 Defender 110 Puma 2.2 USW Corris Grey
I was quite surprised too Chris, all us new South West Puma owners need to meet up to exchange knowledge
Post #269627 26th Sep 2013 6:18pm
Skippy Blue
United Kingdom 2013 Defender 90 Puma 2.2 XS CSW Loire Blue
This thread is valuable advice. I spent ages at the weekend looking for a cause , assuming it was a vibration from the intake being amplified by the wing panel. Now that I know it is normal, I can just enjoy it as a power growl !
Post #270505 30th Sep 2013 7:24pm
gbmud
2005 Defender 110 Td5 HT Belize Green
I am not yet getting used to/enjoying it. I find it irritating.
Chris
Post #270506 30th Sep 2013 7:26pm
Happyoldgit
How are you finding the throttle response, engine braking, gearchange etc Chris? Steve.
Post #270571 30th Sep 2013 9:27pm
Photoguy1510
New Zealand 2013 Defender 110 Puma 2.2 SW Orkney Grey
Mantec snorkel sorts the noise till you drive next to a concrete barrier you quickly wonder which hose is busted lesson to be learnt, keep windows closed and radio turned up Cool use the creature comfort AC if your hot cant make the fuel economy any worse. 2013 Orkney Grey 110 SE on order should be here on 20/04
Post #270920 2nd Oct 2013 11:20am
Skippy Blue
Actually I agree it is annoying noise. Let's figure the root cause... It isn't induction noise as such, but seems to be a resonant frequency at a certain air flow as defined by the rev range. The filter unit is also well buffered from the engine inlet by a soft hose on the engine sided of the filter. Tracking back, the plastic moulded pipe from the wing to the filter seems not to be the culprit either since bracing this firmly has no effect. This leaves the immediate cavity behind the wing grille which I think is acting like a drum since you can feel outward pressure pulses even with air flow inwards. Adding a snorkel seems like it is just dissipating this frequency up the tube. So that's my theory. What I am contemplating is adding some weight to the plastic back of the initial intake point so as to throw it off its harmonic frequency. That's a job for the weekend and I will update with the outcome. Fingers crossed....
Post #271045 2nd Oct 2013 8:24pm
big steve
United Kingdom 2015 Defender 90 Puma 2.2 HT Montalcino Red
It's just the turbo sucking in air my 3.2 does it and I don't have any of the standard air box inlet 2015 2.2 tdci hardtop xs
3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P
hybrid turbo in build -done ready to fit
ashcroft atb in transfer box
6 speed auto in build
Post #271051 2nd Oct 2013 8:43pm
Skippy Blue
My experiment failed - I put aluminium bracing strips inside the inlet area to stop it vibrating. May have helped very slightly but with the grill off and the engine running there is quite a pressure wave pulse coming down from the air filter. Not figured out how to kill that - maybe I will go the snorkel route but that seems expensive
Post #271722 5th Oct 2013 9:18pm
big steve
By going the snorkel route all your going to do is starve the engine of air which will make your performance poor !
Just leave it it's one of a defenders many quirky things
Steve 2015 2.2 tdci hardtop xs
Post #271729 5th Oct 2013 9:43pm
Page 2 of 2 <12
