Home > Puma (Tdci) > Defender Puma rear axle
vodonos
Slovenia 2012 Defender 110 Puma 2.2 SW Sumatra Black
Rear axle Defender puma vs. rear axle Discovery 1 300 tdi. What is diferent?
I need complet rear axle for may def 110, but second hand Discover 1 axle is much esier to get.
Thanks in advence
Mulec BOŠTJAN
SLOVENIA
Cerknica lake
90 td5 2000
110 2,2 2012
Post #268343 21st Sep 2013 4:12pm
geobloke
Hi Mulec. You really only have 2 options for a 110 rear axle and that is due to the weight bearing capacity. You have the Salisbury and the P38 axles to choose from, they are rated for use on 110s and 130s. Whereas the Rover rear diff is only rated for the lighter 90 and Discovery.
I guess it depends what you plan to use the 110 for, if light weight jobs then the Disco axle would do, but if overlanding or heavy weight jobs then you will need either the Salisbury (found on 110s up to 2001) or the P38 axle (found on 110s from 2002 onwards)
Post #268353 21st Sep 2013 5:53pm
Just to clarify it a little bit, it's not actually a P38 "axle", only the differential is the same as the 4.6 (and maybe the 4.0? not 100% sure) REAR P38's.
The axle casing itself is specific to the 110 rear. eventhough it looks like a disco/rangie classic rear axle, it's a lot stronger (much thicker metal, about 5/6mm) and has the normal disc brakes you find on the back of a disc braked salisbury 110.
Post #268389 21st Sep 2013 7:42pm
geobloke
Cheers Jim, I wasn't too clear there. Thumbs Up
Post #268398 21st Sep 2013 8:17pm
vodonos
Thank you guys. So i will take 110 Rear axle.
Best regards
Mulec BOŠTJAN
SLOVENIA
Cerknica lake
90 td5 2000
110 2,2 2012
Post #268885 23rd Sep 2013 7:58pm
geobloke
No problem, it is your best bet, if more expensive and difficult to find.... Thumbs Up
Post #269159 24th Sep 2013 7:31pm
