![]() | Home > Technical > Light switch power load |
WelshGas Member Since: 01 Oct 2010 Location: Vale of Glamorgan Posts: 935 ![]() ![]() ![]() |
You will have to take the headlights out to change over the connectors.
![]() The biggest problem I had was the alternator feed. On the Puma you just cannot get to the rear of the alternator to attach the feed without removing the alternator so I have just run a heavy duty cable back to the + on the battery. All works fine and if for any reason I do have to remove the alternator then I'll wire the feed in but in the meantime the feed from the battery will do the business. ![]() ![]() Neighbourhood Watch for Land Rover Owners http://www.landywatch.co.uk/smf2/index.php |
kmac Member Since: 07 Oct 2009 Location: Middlesex Posts: 1314 ![]() ![]() ![]() |
Do you mean by unscrewing from the front of the vehicle? Would have thought that a battery connection would be fine for headlamps - no need to really wire up to alternator. |
Yes, you have to remove the Headlight trim each side. 2 screws on the trim and remove the sidelight and indicator, 2 screws each. Then there are 4 screws holding the headlight at approx: 11, 1, 5 and 7 o'clock . Don't touch any other screws or you will have to re-level headlamp. The headlamp then lifts forward, or up & forward if you have headlamp levelling. Have fun.
Blott Member Since: 12 Aug 2013 Location: St Ives, Cambridgeshire Posts: 7 ![]() ![]() ![]() |
Hi Guys,
I got this loom as the light switch on my 2002 TD5 decided to die during the MOT test having checked it all the night before. Having got the loom I am struggling to get it all working. It looks like plug and play but I suspect I have made a wrong connection somewhere. I have it earthed to the body OK. The alternator on my TD5 has a push fit multi plug socket on the back and on the side visible, a terminal to which a heavy duty wire goes and which is covered by a rubber cap. Is it that terminal to which I connect? I have tried it and with every thing connected and plugged in still no lights. If I unplug the loom and reconnect the old headlight supplies all work OK. Puzzled. Thanks. Blott Blott |
Surely the live and earth should go directly to the battery if its a loom to take the load away from the switch.
Hi Blott, that is correct. The loom basically is connected to the -tve and +tve of the battery. This can be done in a number of ways. -tve direct to battery or to a good earthing point on the chassis/body/engine/drivetrain.
+tve direct to battery , or as you pointed out the +tve lead connected to the alternator, which is connected to the +tve of the battery. The new loom and relays now carry the current for the headlights and the head lamp switches now just switch the relays only. ![]() ![]() Neighbourhood Watch for Land Rover Owners http://www.landywatch.co.uk/smf2/index.php |
The +ve off the alternator is definitely live and as the others are all "plug and play" I suspect it's the earth. I will run it back to the battery -ve and see if that's the cause and if we have light. Should be simple but with a Land Rove who knows.......
Blott Blott |
Please don't take offence. But you have replaced or repaired the headlight control switches that failed?
No offence taken! Switch was changed for a new unit to pass the MOT. Lights work on the old arrangement, just need to get them working with the purpose made loom extension which includes the relays.
Blott Blott |
I earthed mine to the main earthing point on the chassis that the earth cable from the battery is attached to, not the body. The +tve was connected to the battery directly as it is virtually impossible to connect to the output terminal of the alternator on a Puma, without a lot of dismantling . Hope you sort it out. One thing, check the fuses on the loom are OK.
Merlin Member Since: 30 Oct 2010 Location: Newmarket Posts: 981 ![]() ![]() |
There is a video on You Tube showing how someone has done this mod. Trouble is it's all in Australian! And no sub-titles!
Is there a kit in the UK? Merlin |
Thought it worth mentioning a problem I have had with a loom I bought of fleabay. The loom worked, or so I thought, and everything seemed ok. Then I realised that there was no 'flash' on dip. All alright without the lights on, but when on no flasher.
It turns out that the supplier thought it a good idea to wire the relays so that you can't have dip and main beam on at the same time. So if you had dip on you couldn't flash the headlights. If you have fitted one of these fleabay looms, have a try flashing with the lights on, you never know you might have bought the same one I had. Merlin |
Sadi Member Since: 23 Jul 2015 Location: Windhoek Posts: 334 ![]() ![]() ![]() |
Did you notice any improvement in the amount of emitted light? The loom - does it have thicker cables to decrease the voltage drop - as compared to the OEM cables? Any photos available of your installation - from the battery to relay fixture? On the Landreiziger website it mentions their loom as "The Swedish Light Switch" - due to Swedes swopping to 90W globes - in which case you need the relays to protect the OEM switch. Thanks. |
Reminder about everything said before on this excellent Landreiziger loom. You can read everything you need to know about Voltage to headlights increase in below thread. Especially see the post by Tiger with the pictures.
http://www.defender2.net/forum/topic26097-105.html And, contrary to what some say, you do not need to connect the + feed all the way to the battery, you can connect that to the alternator, so it all stays nicely under the bonnet. As to thicker wires, the loom was installed by my dealer, and the only thing they changed was replacing the - feed black wire by a thicker version, and simply connected that to the airco compressor where a small nut to allow this is already in place and has actually no other purpose. This would avoid any possible future deterioration of the - feed if connected elsewhere. See picture. ![]() Click image to enlarge Excellent proven quality piece of kit, probably not a good idea looking on fleabay for a cheap Chinese copy. Eric You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
