![]() | Home > Technical > Spot Lights-Universal fit? |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6126 ![]() ![]() ![]() |
Most are, yes. usually an M12 or so stud with several large washers/rubber bits and a nut.
And most spots you can rotate the lense around in the body, so you can mount them "upside down"... as in, on an A bar they'd hang down from the top, and n a nudge bar they usually sit on a shelf. Only thing to check is the diameter of your lights... (assuming they're round) that they will fit into the A bar. |
Litch Member Since: 10 Mar 2013 Location: Oxfordshire Posts: 765 ![]() ![]() |
Also check how deep they are.
Depending on how close the A-bar is to the grill, some lights are so deep that you have to remove a section of the grill behind each one. It isn't really a problem in use but it does mean that if you later decide to remove the lights and/or A-bar you have to fit a new grill. ONE LIFE, GET IT! |
