Home > For Sale & Wanted > [Wanted] Wanted 10AS alarm ECU ending 280
Macpaul
United Kingdom 2013 Defender 110 Puma 2.2 USW Loire Blue
Hello All,
I want to retrofit central locking and need an ECU part no. YWC106280 for my poverty spec 2003 Td5.
Its the green box behind the dash.
The one ending 270 won't do alas.
Is there one out there?
Simon 2003 Td5 110 Hardtop
Now a 2013 110 USW too.
Post #267010 15th Sep 2013 7:15pm
ickle
You can piggy back a remote c/l relay off the multi plug on the relay, bought off fleabay or if you're adept with circuit boards, solder a relay off a scrap disco board onto your board.
Keith Thumbs Up
Post #267015 15th Sep 2013 7:26pm
Macpaul
"You can piggy back a remote c/l relay off the multi plug on the relay, bought off fleabay or if you're adept with circuit boards, solder a relay off a scrap disco board onto your board. "
I feel like Cletus on The Simpsons.......!
Mind you, i'm getting used to it. 2003 Td5 110 Hardtop
Post #267036 15th Sep 2013 8:04pm
ickle
You've lost me there Cletus!
http://www.ebay.co.uk/itm/Central-Locking-...4ab41fdc78
This is the one I used - works utterlydiidlydacious!
Flanders
Post #267045 15th Sep 2013 8:29pm
O/T
Care to give the pin connections of what you did? Thumbs Up
Post #267051 15th Sep 2013 8:41pm
Macpaul
https://twitter.com/cletus_d
Thanks but for the money the xxx280s seem to have been available for in the past, I'd still go with a new unit.
I hate/am no good at soldering.. 2003 Td5 110 Hardtop
Post #267052 15th Sep 2013 8:41pm
ickle
Jim - I've photos somewhere - I'll search
Simon, three years ago the 280s were £130+ & for a tenner and an hour got the CL working perfectly, good luck
Keith
Post #267065 15th Sep 2013 9:02pm
Macpaul
Ah. The last 280 I saw on ebay (hadn't worked out I needed it) in August was £39 + p&p
http://www.ebay.co.uk/itm/151087331497?ssP...1423.l2649
There's a 270 thats been on offer for ages at £75 buy it now but no interest.
If you're right it's out with the soldering iron but I'm hoping someone on here might have one. 2003 Td5 110 Hardtop
Post #267068 15th Sep 2013 9:13pm
ickle
Here's the two photos of the connections on the pcb - I'm sure they will give the electronics experts on here palpitations, but still going strong after three years!
As long as you don't want to know where they connect to on the relay.....I can't find that photo, but if needed I can drop the relay and check, from memory, its easy to check where they go to with a 50:50 chance on the open close circuits.
If you haven;t realised its possible to fiddle the ecu out through the speaker hole, speeds things up!
Keith
Post #267245 16th Sep 2013 6:17pm
