Home > In Car Electronics > Dash Switches |
The proper auxilliary lighting switch is part no. YUG000540LNF but it's become very expensive in recent years:
http://www.lrseries.com/shop/product/listi...WITCH.html Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
1st Sep 2013 9:00am |
Bows Member Since: 07 May 2012 Location: Wales Posts: 516 |
Great work, thanks, your searching skills put mine to shame. £53.56 inc the vat!! Ouch!! Arjay Motor Factors it'll be I think. It's extremely difficult to justify the best part of £55 for a simple on/off switch!
Thanks again for finding the item though. |
1st Sep 2013 9:25am |
Go Beyond Member Since: 30 Jan 2012 Location: Headcorn, Kent Posts: 6678 |
Here's another option
http://www.mudstuff.co.uk/products/interio...plate.html |
1st Sep 2013 9:38am |
msb Member Since: 28 Feb 2013 Location: Leeds Posts: 78 |
Have a read of this....
http://forums.lr4x4.com/index.php?showtopic=84901#entry728827 ...with a little bit of work you can use the £5 switches. HTH Cheers Mike |
1st Sep 2013 6:26pm |
I've had another idea, is there any reason why I can't get a second rear fog light switch and mount it upside down? It'd almost look identical to the front fog switch but cost £9 and not £55.
Cheers |
10th Sep 2013 9:40pm |
Rear fog light switch is a 'momentary' one not on / off
10th Sep 2013 9:44pm |
Foiled again, any other suggestions? thanks
11th Sep 2013 5:25pm |
mk1collector Member Since: 17 Sep 2009 Location: West Yorkshire Posts: 6772 |
Heated seat switch
11th Sep 2013 5:27pm |
appaloosadude Member Since: 17 Oct 2012 Location: Buckinghamshire Posts: 630 |
Latching relay with the rear fog switch - press on, press off. |
12th Sep 2013 5:54am |
TD5 heated seat switches are silly money.
I did think of some sort of latching relay but couldn't think how to make it work, could you put up circuit diagram please ? |
12th Sep 2013 6:03am |
Click image to enlarge I think would be correct, with one output left clear. I imagine there is a better alternative, but brain function is not yet 100%! |
12th Sep 2013 6:10am |
That same switch also exists in a different version. The looks are identical, but it is a latch on / latch off switch. When my dealer installed my front fogs, he used that switch for the fogs in the empty space on the Puma. It is wired up so that the fogs will only come on together with the parking lights or low beam, go off again with high beam. But if you leave the switch in the latch on position, when switching back from high beam to low beam, the fogs will come on again. Surely you could use that switch which probably is cheaper for any aux lamps. It is the same function principle as the now expensive YUG000540LNF. Don't have a price or part number, but ask a decent LR dealer. Below is a picture with at the left side the rear fog light switch which is like Go beyond explains, and on the right side is the switch with the same looks, but latch on / latch off type. Click image to enlarge You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
12th Sep 2013 6:23am |
Use a tdci heated seat switch but replace the cap with the blank cap. All you need to do is drill a small hole for the light and you can scratch any picture you want into the blank cap. I think paulmc on here did a write up on lro about it a while back but I can't find it now |
12th Sep 2013 8:20am |
udderlyoffroad Member Since: 18 Jul 2011 Location: Bristol Posts: 124 |
Not sure about the switch p/ns more modern landies have, but a Durite p/n 0-728-02 latching relay will take a momentary switch input and give you proper on/off functionality.
Real trucks don't have spark plugs |
12th Sep 2013 2:55pm |
