Home > Pictures & Video > Light Reconnaissance Vehicle 400 (LRV 400) |
"A militarized variant of Qt Services’ successful `Wildcat` off-road motorsport vehicle" so there might be some defender under there somewhere? More here - http://defense-update.com/20130910_supacat...-2013.html Possibly most interesting - "It can be fitted with a range of powertrain options – the display vehicle has a Ford 3.2-litre, 5-cylinder diesel engine developing 236 hp and 550 Nm torque coupled to a Ford-supplied 6-speed automatic gearbox and two-speed transfer box however, other engine and transmission options are available." |
11th Sep 2013 6:28am |
Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6300 |
i like it !
great stuff. |
11th Sep 2013 6:44am |
theorangebandit Member Since: 03 Jun 2013 Location: Stowmarket Posts: 862 |
Shane the army won't buy it and they don't need it really the jackel isa brilliant recce vehicle
11th Sep 2013 8:03am |
Glynparry25 Member Since: 16 Feb 2009 Location: Miserable Midlands Posts: 3015 |
No chance the British army will take it- probably aimed at 'foreign' armies.
The British army even cancelled the last batch of Jackals because they aren't what they want anymore- not enough protection. Glyn |
11th Sep 2013 9:42am |
Have you got any more info on the cancelled order? Not seen anything about that.
I'm hoping they do buy a few...as what goes in one end eventually ends up coming out the other at Withams and a little video here: http://www.foxnews.com/tech/2013/11/12/arm...-brew-tea/ |
11th Sep 2013 10:40am |
Mk II version released and it's now based on the Discovery rather than Wildcat.
The LRV 400 has the unique feature of being convertible from 4×4 to 6×6. The LRV 400 has front and rear independent double wishbone air suspension offering variable ride height and lock out – bump stops for stable firing and high power to weight ratio. Powered by a V6 3.0 turbo diesel providing 256 bhp and 600Nm Torque , it has an 8 speed automatic transmission and high and low permanent 4WD with centre diff lock. Cross-axle diff locks are also available as an option. https://vimeo.com/139381405 |
12th Sep 2015 8:21am |
Click image to enlarge Now out and about. Who needs a new Defender, when this ticks so many boxes? |
13th Apr 2019 3:07pm |
ibexman Member Since: 13 Dec 2008 Location: Essex Posts: 2945 |
What ^^^ he said
13th Apr 2019 3:34pm |
Pilgrimmick Member Since: 16 Nov 2015 Location: Highlands Posts: 582 |
Look at the ramp break over angle, like a bus, will not get far without getting stuck. 80" 1948
Lightweight V8 Bowler Tomcat 130 Station wagon 90 300tdi (Santana PS10 pick up) Range Rover L322 (Ful fat) |
13th Apr 2019 6:53pm |
Ramp angle is 153°
Ground clearance is 180mm (loading) & 320mm (standard). If that's you definition of a bus, I'm happy to drive a bus 😉 |
14th Apr 2019 6:42am |
