Home > Puma (Tdci) > Oh no I've turned into Caterham
Sockpuppet
5 days old and I'm already on my first warranty claim Rolling with laughter
Nearside rear passenger seat folded down but won't fold back up Big Cry
The other side works ok so it's not me being silly. Sounds like a dodgy mech, would usually just sort it but it's under warranty so back to the dealers it goes. Laughing
Post #265139 10th Sep 2013 11:52am
Happyoldgit
Niggly things like that can take the shine off a new toy. I'd be more than niggled as there is no longer a LR dealer within 40/50 miles from me. Steve.
http://forums.lr4x4.com
Post #265144 10th Sep 2013 12:07pm
Shep
2010 Defender 110 Puma 2.4 USW Orkney Grey
Mine sticks as well, i just need to fiddle with the lever whilst wiggling the seat and it all works again for a while. A man with no boat is a prisoner
Post #265150 10th Sep 2013 12:18pm
Sockpuppet
Yeah, its happened on the first day and I got it to go back up however when I did it again it didn't do it.
Would be annoying if it happened anywhere i needed 5 seats as well.
Post #265151 10th Sep 2013 12:21pm
If the base isn't properly clipped down, the backrest won't go up. Quite often I have to give mine a fair old bang downwards before the back will go up.
Post #265153 10th Sep 2013 12:24pm
Shep
I find it annoying anyway! Just out of warrantee for me so its DIY for me. A man with no boat is a prisoner
Post #265154 10th Sep 2013 12:25pm
Caterham
hope they sort it without any fuss.
I can confidently say mines all good (did have all the seat frames replaced so that might be why I'm not having any problems with the seats?) Thumbs Up
I hope you're enjoying all the same?
I think I now know why they come with a 3 year warranty. it takes that long to sort it all out Rolling with laughter
I have to say I only got 50 yards from the dealers and should have guessed I was in for trouble when it started kangarooing Crying or Very sad
hopefully this will prove to be your first and only problem.
Post #265173 10th Sep 2013 12:59pm
Happyoldgit
If the back refuses to go up it can be down to the grub screw on the latch inside the seat coming loose - can be got at once the plastic trim is removed. Steve.
Post #265180 10th Sep 2013 1:11pm
smb
Is it the whole seat that won't go back up or is it just the back part? If its the back part then push the grab handle down. When you pull it up to move the back rest down it doesn't always spring back to neutral position.
Post #265191 10th Sep 2013 1:41pm
Sockpuppet
Its the seat back, gets to about 30 degress from flat then stops. I'll give it another whirl when I get home.
Post #265196 10th Sep 2013 1:58pm
smb
Ok, pull the lever up to lower the backrest. Lift the loop handle to swivel the full seat forward. Make sure nothing is blocking it returning. Swivel the full seat back and using a little force try and push the seat into its mounting locks. Get hold of the loop handle and push it down. You should then be able to move the backrest back into position.
It is a very common fault and whilst you can take it back for warranty work it is a lot less hassle to understand what the problem is for when it happens the other side.
I hadn't a clue until I read about it on this forum.
Post #265202 10th Sep 2013 2:18pm
Sockpuppet
It was the handle at the back. Wasn't returning down when the seat base was pushed home. Pushed it down and it's all ok. Result as the dealer is a bit of a mission away.
Post #265253 10th Sep 2013 5:12pm
Shep
Good news, after reading this thread i had a good look around mine and the seat base wasn't locking down completly due to a stray bit of plastic from somewhere.
Seat works fine for now Thumbs Up
Just got to find where the plastic came from now!
Shep A man with no boat is a prisoner
Post #265269 10th Sep 2013 5:39pm
skyeplumb
Scotland 2007 Defender 110 Puma 2.4 USW Rimini Red
Mine does it too, just have to remember to push the loop hande down before lifting the seat back up. Series IIa Lightweight - Long Gone
Discovery 1 300Tdi - Sold
Defender 110 XS 07MY Utility
Post #265271 10th Sep 2013 5:40pm
rossy
yeah mine was the same but it kind of fixed itself after a few wiggles of the lever Confused
Post #265321 10th Sep 2013 7:27pm
