- You are currently viewing DEFENDER2.NET as a guest - Register to take part or Log In
Glynparry25
If you go to any motor factor shop you should be able to find one made for the Ford coupling.
Draper make one and as far as I remember it is priced at about £10-15 where from an old post I believe the LR item is priced over £100?
If you really can't find anything, the first time I bled mine (before I made an adaptor) I used a piece of pipe the diameter of the plug on the end of the pipe just means it doesn't lock into place- worked a treat.
If it is just for a filter changer there is no need to bleed the system- old one off, new one on and then start and leave to run on tickover for a few mins
Glyn
10th Sep 2013 10:37am |
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
