![]() | Home > Td5 > Heavy breathing and smoke from filler cap and dipstick.... |
ARC99 Member Since: 19 Feb 2013 Location: North Yorkshire Posts: 1831 ![]() ![]() ![]() |
I would have suggested head gasget as a possible reason, and thats from previous experience. The last time it happened to me it blew the oil and water out of the dipstick. Don't make old people mad.
We don't like being old in the first place, so it doesn't take much to ![]() Richard |
S3dxm Member Since: 17 Aug 2013 Location: York Posts: 82 ![]() ![]() ![]() |
Thanks for the info,
Did you see any tell tale signs on the head or gasket to show damage or any deformation? Cheers! |
Not before it was stripped afterwards only then with a known true edge and feeler gauge, still wasn't sure so had test dial indicator run over the head and block which showed that they were not true, resulting in both being ground flat. Don't make old people mad.
Thinking a very light skim to clean to start with (payment in beer as a mate will do it)
Then just need to get it pressure tested.... Fingers crossed I don't need a new head. |
