Home > Expedition & Overland > now in croatia.need help
womble
hello all,i am currently in croatia and have a gearbox problem,very stiff between gears,suspect oil but maybe a bigger problem.does anyone know of anyone who could have a look tomorrow . we have 2 dogs with us and due to pet passports we have to cross into uk on monday 9th. Big Cry Bow down
Post #264264 6th Sep 2013 4:20pm
Lou Sparts
United Kingdom 2005 Defender 90 Td5 XS CSW Zambezi Silver
If you get to a point where you are unable to change gear you can select 3rd or 4th and pull away in low range and change to high range once you get a bit of speed up. Its amazing how far you can go like this (when you have to) i had to do this once when i lost all my clutch fluid.
Have you checked Clutch operation ?
Good luck Thumbs Up 2005 Td5 90 XS
Steve
Post #264331 6th Sep 2013 9:02pm
womble
hi and thanks for your advice.we found a mechanic and the oil is ok and there is enough oil.he thinks it is the syncromesh between 3rd and 4th that is the problem so i hope we can get home.many thanks for taking the time to reply. Thumbs Up
Post #264337 6th Sep 2013 9:15pm
