Home > In Car Electronics > Pad mount arrived
Page 2 of 3 <123>
Kitoper
Switzerland
ericvv wrote:
How nice an installation that is, LR did really a good job with those SVX Garmins Whistle Whistle
Thumbs Up
Post #262366 30th Aug 2013 10:01am
Thanks for the write-up, D J. I've just ordered one. Darren
Post #262682 31st Aug 2013 5:50pm
kjmeijer
Netherlands 2016 Defender 110 Other SW Galway Green
RichardBattersby wrote:
kjmeijer wrote:
The Ram still is a well made universal (for smal tablets) solution. I fitted mine without drilling etc. and it still sits very sturdy:
Where did you get this from? I can't seem to find it on the net but looks really good.
I got it from www.rammounting.nl but any Ram dealer should be able to supply you. 2021 Defender 110 D300 HSE
Post #262689 31st Aug 2013 6:15pm
RichardBattersby
Post #262821 1st Sep 2013 9:09am
d j hutton
England 2011 Defender 110 Puma 2.4 USW Orkney Grey
Brendan at 4x4 overlander most likely will be able to supply the Ram mount - site sponsor on here Thumbs Up
DJ 1989 200tdi 90 csw
2011 110 usw Orkney grey
Buy British 🇬🇧
Defender Clothing Designs available at http://www.rangesports.com/acatalog/Defender-Stuff.html
Post #262881 1st Sep 2013 2:01pm
Mine arrived today - very promptly from Gearzap - and it was fitted in about five minutes flat this evening:
Seems very sturdy and excellent value for money Thumbs Up Darren
Post #263561 3rd Sep 2013 9:05pm
borderterrier
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Aintree Green
Does it move/vibrate when you drive at all, the flexible arm looks very long?
Post #263564 3rd Sep 2013 9:14pm
I'll have to let you know tomorrow when I've driven it. DJs' report above suggests it's ok though. Darren
Post #263584 3rd Sep 2013 9:55pm
borderterrier
Thumbs Up
Post #263585 3rd Sep 2013 9:57pm
Tested on the drive to work this morning and it's pretty good. It sways a little bit over bumps - maybe 15-20mm overall - but my iPad 1 in its' Otterbox is a heavy beast. The ball mount is rock solid and the arm is very stiff but at 450mm long it's bound to have some play in it.
Over all, very pleased. Darren
Post #263668 4th Sep 2013 11:11am
Lorryman100
I have the RAM one fitted to hold a playbook in an otterbox. It is a solid bit of kit but does vibrate due to the length of the arm. I did the same and fitted it onto the passenger seat mount. Next job when I get some time involves fitting one of mobile centres dual usb charging sockets into the GMB electrical box and running a suitable usb lead up the inside of the plastic tube so the playbook is plugged in and powered all the time.
Post #269953 28th Sep 2013 3:31pm
leeds
Brian, if you do sharper bends then you will lessen the effects of vibrations travelling up the flexi arm.
Sometimes easier to bend it sharper out of vehicle using say a vice and oversized tube to get tighter bends.
Brendan
Post #269988 28th Sep 2013 7:00pm
borderterrier
Here is my set up for my iPad mini. I opted for the RAM mount and the shortest possible distance between attachment to vehicle and iPad to reduce vibration. Result is a very solid solution, on and off road. iPad can be facing the driver, or both driver and passenger as required. Very Happy
Post #270133 29th Sep 2013 1:51pm
party monkey
England 2005 Defender 110 Td5 XS CSW Cairns Blue
Just wanted to add a word of thanks to DJ for highlighting this very reasonably priced mounting idea. Bow down Finally got around to fitting it (in minutes as LRA commented) yesterday.
I've not used it in anger yet but for the money involved and ease of installation, it's almost rude not to give it a go. Jon - 110 td5 [sold]. Currently Defenderless.
Post #275247 20th Oct 2013 1:59pm
kjmeijer wrote:
Does this mount fit a full size iPad ? Also can't seem to find this one over here in the UK or am I not looking hard enough? KEEP CALM AND Drill ON
Post #276222 23rd Oct 2013 10:19pm
Page 2 of 3 <123>
