Home > Puma (Tdci) > How to bleed the clutch slave cylinder?
driver
United Kingdom 2007 Defender 90 Puma 2.4 HT Stornoway Grey
Hi,
I have just renued the brake fluid on my 07 defender as the colour was quite dark, bled the brakes and all went well so I thought I would do the clutch as well,
So I have syphoned off the old fluid as it was a horrible grey milky colour and replaced it with mobile dot 4,but when it came to bleeding the clutch all I can find is a black plastic unit with a bleed nipple on it on the gearbox bell housing
is this the right one?
Also is it bled in the same manner as the slave cylinder on a 300tdi? as its plastic I dont want to break it now they have seen fit to put the slave cylinder inside the bell housing.
So any advice from someone who haas done this before or a couple of pictures would be great.
On the plus side the gear changes felt a lot smoother and less snaggy today.
Post #263110 2nd Sep 2013 12:51pm
Dieselhead
Yes you have found it Thumbs Up
It only does move one way if I remember. We just put an easi bleed on it & pumped/poured etc until new oil came through
It was quite easy if you ask me
Sorry no pics Embarassed Chris
2008 XS 110 2.4 Utility. Tonga Green
1953 Series 1 for restoration
1983 Mini Mayfair
2004 VW T5 Camper
2008 Diahatsu Sirion. Thats hers
Classic Bolens Garden Tractors
Post #263160 2nd Sep 2013 4:49pm
driver
Cheers, another job to finish at the weekend now Very Happy
Post #263181 2nd Sep 2013 5:54pm
