Home > Puma (Tdci) > Performance Test pre / post remap
BigGeorge
Switzerland 2010 Defender 110 Puma 2.4 SW Keswick Green
I came across two performance test diagrams recently.
I was surprised to see that both were showing torque values of 300 and shortly below 300 NM, whereas LR brochures make us believe they TDCi engines produce 360 NM torque. Is this coincidence or do LR systematically reduced NM because of some issues with gear box / transfer box and differentials?
Has anyone else tested the performance? The goons are trying to bring me down!
Defender 110 SW MY10 useless piece of Censored ... but I like her
Defender 90 V8 50th Anniversary
Series IIa 109 / 6 cyl. ex-fire truck
Post #26223 8th Mar 2010 3:38pm
Glynparry25
Land Rover use NM, where most aftermarket companies use lb Ft,
360NM is about 265lb-Ft.
Glyn
Post #26236 8th Mar 2010 4:18pm
BigGeorge
thanks for the clarification / calculation into lb ft.
the graphs seen stated NM.
George The goons are trying to bring me down!
Post #26241 8th Mar 2010 4:32pm
K9F
Not 100%sure what it is you're after but here are some more figures for you to look at:-
LAND ROVER DEFENDER 2.4 DIESEL 2007 ONWARDS
Power:- Standard Max Power 119 BHP
AUTOLOGICŪ Max Power 149 BHP
Torque:- Standard Max Torque 314Nm
AUTOLOGICŪ Max Torque 393Nm
More graphs here:- http://www.james-french.co.uk/power-upgrades.asp
Hope this helps! Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #26242 8th Mar 2010 4:39pm
BigGeorge
bingo... that's the stuff, but not from companies advertising for their products, but more from drivers actually buying that stuff and having the performance measured pre and post tuning.
Post #26243 8th Mar 2010 4:52pm
K9F
Extra Torque and Horsies!
BigGeorge,
That's what I had done and it is excellent! All facts and figures were laid out before you and I had a detailed discussion with the Workshop Manager beforehand who answered all my queries. A lot of people offering tuning services can be a little 'vague' when it comes to post installation performance figures! People, myself included, want to know in priority how much extra torque they're getting and how many extra horses underneath their bonnet they get for their hard-earned money! If you go through life with your head in the sand....all people will see is an ar5e!!
Post #26246 8th Mar 2010 5:12pm
Glynparry25
How are people measuring them?
Unfortunatly 'Rolling Road', and 'power meters' are hugely innacurate when it comes to flywheel readings, they measure at the wheel and then makes a calculation to work out the engine power. As you can guess, without knowing the exact power loss through the drivetrain you can't calculate the power at the flywheel.
The only way to do it properly would be to have the engine on a Dyno bench which is what would have been done in the first place to get 122bhp and 360Nm. Unfortunatly unless you are going for a complete new loom and aftermarket ecu taking theengine out and onto the bench is a bit OTT.
Glyn Sheep
Post #26253 8th Mar 2010 5:40pm
dgardel
Italy
REMEMBER!!!
HP and torque are referred at the crankshaft not at the wheels..... (all cars, all types) at STD environment conditions (NN°C, xyz mmHg atmospheric pressure, abc % of humidity,.....)
Are the correction parameters inputed on the bench SW? if yes are they corrects????? Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #26273 8th Mar 2010 7:28pm
Ads90
United Kingdom 2007 Defender 90 Puma 2.4 CSW Keswick Green
Anyone remember reading a huge discussion/argument on LRnet few years ago between a guy who claimed his TD5 was the fastest on earth, and another who wanted to prove him wrong? (May have involved a certain air-intake device which I'm too wary to mention)!
Seems the only fair way (apart from a bench of course) is to get a standard vehicle and chipped example on a rolling road one after the other, not scientific, but you'll get a decent bhp/torques comparison at the wheel...
Post #26325 9th Mar 2010 9:56am
K9F
Who really cares?
As 'a layman and a customer' should I really be concerned as to how the actual final figures were derived? On a bench, engine out/engine in, rolling road or 1 in 10 downhill gradient with a tail wind? Personally I think not! My opinion only admittedly! I was informed 30 extra nags and 80nm of extra torque that would improve the driving experience. 'Pays your money takes your choice!'
With all the sales pitches the end result for me after spending my hard-earned was indeed a new driving experience that initially seemed like I had a rocket up my ar5e with an element of guarantee it was not going to be to the detriment of the engine and better fuel economy to boot, what's more my annoying 82mph limiter also disappeared! Result!
Some 13 months later I am still happy, engine still runs and I do have marginal better economy, the sun is beginning to shine and Summer is just around the corner, happy days or what?
Thumbs Up Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #26332 9th Mar 2010 11:05am
DAZ110
United Kingdom 2013 Defender 90 Puma 2.2 XS CSW Barolo Black
Well said K9F Thumbs Up
Post #26341 9th Mar 2010 12:38pm
