![]() | Home > Td5 > Remove Door Hinges |
WarPig Member Since: 04 Dec 2009 Location: Sheffield Posts: 1748 ![]() ![]() ![]() |
Are you refering to the front or middle doors?
On the middle doors the nut at the bottom of the B (not bulkhead) pillar is in fact a rectangular plate with captive nuts. When the bolts are removed the plate may just fall to the floor. On the front doors, the bolts go into captive nuts that are held in the bulkhead. ![]() Click image to enlarge As for removing the stem, can you get any grips on it to turn it, to cut a groove in it and use a flat screw driver? Ive sent you a PM that includes a photo guide of how to remove door hinges. :thumbsup: Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() Last edited by WarPig on 30th Aug 2013 9:48am. Edited 1 time in total |
Roy l Member Since: 01 Aug 2013 Location: Surrey Posts: 9 ![]() ![]() ![]() |
Sorry. I should have said.
Its the middle doors and the problem hinge was attached to the 'B' pillar. Thanks Defender Virgin - go gentle with me! |
Ok, ignore the above photo then. And ignore the Pm i sent you as that refers to front door hinges.
if you feel behind the lower B pillar right behind the hinge, you should be able to feel the rectangular plate with two holes in it. Its kind of recessed into the B pillar. Theres no separate nut on this plate, so its not as though you can just loosen the nut off instead. The nut is part of the plate. The upper hinge bolts just screw into the B pillar and can be seen when removing the internal plastic trim. |
Thanks very much.
Will have a look! Cheers again Defender Virgin - go gentle with me! |
Perfect!!!!
I didn't appreciate that you accessed the back of the hinge from under the vehicle but thought it had to be done from within the cab immediately behind the pillar. As it turns out, a few gentle taps on the stem pushed the bracket out. Thanks again! ![]() |
airpusher Member Since: 04 Sep 2011 Location: South Wales Posts: 372 ![]() ![]() ![]() |
Hey WarPig,
I've just found this threat as I'm looking at taking my mirror arms off to sand back and spray. Would it be possible to get a copy of that photo guide to removing the hinges? Many thanks 2006 Defender Double Cab- Zambezi Silver |
