Home > Maintenance & Modifications > shock turrets
williamthedog
shock turrets
thinking of fitting a set of heavy duty turrets.
do you have to fit different retaining rings or have the standard ones got long enough threads on them to do the job ?
Post #262403 30th Aug 2013 2:04pm
big steve
United Kingdom 2015 Defender 90 Puma 2.2 HT Montalcino Red
get on to gwyn lewis he does some desent galv rings and turrets i recon are best from devon 4x4
steve 2015 2.2 tdci hardtop xs
3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P
hybrid turbo in build -done ready to fit
ashcroft atb in transfer box
6 speed auto in build
Post #262408 30th Aug 2013 3:04pm
johnszs
United Kingdom 2004 Defender 90 Td5 XS CSW Alveston Red
Devon 4x4 for me i also fitted relocation cones to mine 2004 TD5 Defender 90 xs station wagon
Post #262436 30th Aug 2013 5:50pm
Grey110
Netherlands
You can use the same retaining rings, but the bolts often break when you remove the turrets.
Best to buy new rings as well instead of having to do the job twice (like me Wink )
While you're at it consider replacing the shocks and springs at the same time.
Martin Martin
Previous 2003 Defender 110 Hardtop TD5
2004 Defender 110 Station Wagon TD5 - Libyan Sand
2005 Discovery 3 - V8 - Black
Post #262442 30th Aug 2013 6:03pm
williamthedog
ok cheers,
think it will be a call to devon 4x4 Thumbs Up
Post #262452 30th Aug 2013 6:26pm
Diablo
1984 Defender 90 200 Tdi SW Keswick Green
could fit a set of disco 2 (i think, maybe 1) retaining rings. They come with a rubber donut which gives a better ride/handling and a dribble of a lift too.
Post #262474 30th Aug 2013 7:21pm
Glynparry25
I will add another vote to the Gwyn Lewis setup- cheaper and have the relocation cones built in Smile
Start WD-40ing and wire brush the turret securing bolts way in advance and you shouldn't have any problems with them Thumbs Up
Glyn Dog Sheep
Post #262501 30th Aug 2013 8:54pm
williamthedog
thats todays job sorted then Very Happy
wire brush and wd40 at standby Thumbs Up
Post #262552 31st Aug 2013 6:50am
williamthedog
Post #262553 31st Aug 2013 6:51am
Glynparry25
I should also add..... Still buy a set of securing rings in advance- Nothing worse than them shearing and the truck off the road whilst you try to source a new set Smile always easy to sell on after or return to where you got them from Thumbs Up
WARNING time: Britpart Securing rings do not come with nuts, and they aren't metric Rolling Eyes So either buy better or take it to a hardware store and have the correct nuts before starting the job (From Experience)
Glyn Dog Sheep
Post #262568 31st Aug 2013 8:10am
williamthedog
Cheers Glyn,
went out to attack it earlier,every nut undone sweet as a nut.
did landrover put grease on mine- that will be a first Rolling with laughter
Post #262588 31st Aug 2013 9:44am
Glynparry25
I just looked....... 2011 Defender..... Yeah, that will be fine, lol Rolling with laughter
I was thinking of 5+ year old motors
GLyn Dog Sheep
Post #262820 1st Sep 2013 9:08am
