Home > Technical > Speedo now reading double
Sphere
United Kingdom 2015 Defender 110 Puma 2.2 USW Keswick Green
I looked at a 110 for a friend today who's speedo is showing double the speed. He has recently put a new gearbox and transfer box from a disco 300 in and it's since then there's been a issue so guessing its from this however we have changed the speedo gears to try and rectify the problem but to no avail. One issues its a td5 defender running a 300 engine so it gets a little confusing when getting bits.
Could just be a very fast defender I guess Laughing
Post #262217 29th Aug 2013 6:07pm
landy andy
Is it a case that the speedo drive on a disco is different to a defender? Or is the ECU reading it differently. So can you swap ECU from disco or modify your defender one? Do you have a Nanocom?
Andy
Post #262242 29th Aug 2013 7:38pm
Sphere
I am afraid we have tried that and others. As far as I know we have tried them all including v8
Although its a td5 (v) with a td5 dash it's running a 300tdi. I am guessing this is part of the issue but can't see how. It worked befor the box change and I have been told it ran disco box prior?
Post #262248 29th Aug 2013 7:58pm
landy andy
Quote
The difference between the defender and disco sender is the disco gives twice as many pulses. So on a programmable speedo either will be fine. On a standard defender td5 speedo it's set to 4100 pulses per mile.
Still looking into it.
Post #262252 29th Aug 2013 8:14pm
landy andy
I think you answer is in here.
http://forums.lr4x4.com/index.php?showtopic=70254#entry600667
Andy
My head hurts now
Post #262255 29th Aug 2013 8:18pm
Lou Sparts
United Kingdom 2005 Defender 90 Td5 XS CSW Zambezi Silver
Woo Hoo, at last a Defender that does 50 MPG Whistle 2005 Td5 90 XS
Steve
Post #262303 29th Aug 2013 9:51pm
landy andy
For your information
"For what it's worth, the Disco transducer unit (the small black one, think it has an AMR part number) reads double the number of pulses that the Defender Td5 one (YBE100530) does.
For a Defender Td5 speedo, YBE100530 is what you want. Anything else will mis-read, and a non-genuine YBE100530 will double-read. Never heard of a Britpart YBE100530 not reading double! "
Andy
Post #262306 29th Aug 2013 9:55pm
Quote:
... Never heard of a Britpart YBE100530 not reading double! ...
Another triumph for our favourite parts supplier! Laughing
Post #262352 30th Aug 2013 8:46am
Sphere
Genuine one on order! Should have guessed with britpart was the same price nearly as well.
Was waiting to get stopped by plod yesterday do you know what speed you were doing????
Post #262386 30th Aug 2013 12:22pm
Sphere
Just thought I would update this as fitted the genuine part today and it works.
Lovely britpart does it again
I have said before I will never buy britpart again am I a sucker Question
Post #263793 4th Sep 2013 7:17pm
