Home > In Car Electronics > Parking Brake / Reverse Switch
Nick-St
United Kingdom 2013 Defender 110 Puma 2.2 USW Corris Grey
Anyone know a convenient location (preferably under the dash with easy access!) that I can pickup the reverse switch and handbrake lines for connection to the stereo... I can probably just ground the handbrake one to over-ride it, but apparently some HUs are smart to that...
Post #262008 28th Aug 2013 10:09pm
Parking wire you should* be okay to just ground. The reverse is a bit more complicated though & access is a ..... WeWillWinπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
β›½οΈπŸ›’οΈβš™οΈπŸ§°πŸ’ͺ
Post #262010 28th Aug 2013 10:11pm
william8
Scotland 2008 Defender 90 Puma 2.4 XS CSW Zambezi Silver
I think you would be faster taking the cubby out and going straight to the reverse switch on the gearbox! William
Post #262053 28th Aug 2013 11:50pm
landy andy
Take cubby box out and you will find reverse switch, and handbrake cables.
I am sure it's a stupid question, but, why does your stereo need to be connected to your handbrake?
Andy
Post #262055 29th Aug 2013 12:07am
Lou Sparts
United Kingdom 2005 Defender 90 Td5 XS CSW Zambezi Silver
If you have a head unit capable of showing TV or DVD it must only work whilst the hand brake is on i.e not driving.
At least thats the way i have read it ! 2005 Td5 90 XS
Steve
Post #262056 29th Aug 2013 12:12am
Nick-St
Thanks - I'll have a look under there...
Yes, the HU has a screen & disables some phone & video functions if it thinks the handbrake is off...
Post #262079 29th Aug 2013 7:50am
Unnecessary quote removed
Do you mean it disables tv etc when the handbrake is OFF?
Post #262098 29th Aug 2013 8:56am
Nick-St
Yes - video playback stops & some phone functions aren't available.
Post #262102 29th Aug 2013 9:21am
^^^^ He's right mine does this too! It is illegal to use it whilst driving too but providing you bypass it so it works all the time but you use your own sense not to use video playback etc whilst driving then you are absolutely fine. WeWillWinπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
Post #262109 29th Aug 2013 9:44am
Nick-St
Some of the newer HUs apparently sense the handbrake line... If its permanently low, it assumes its been bypassed and doesn't work! You can get little relay devices to go inline, so the HU 'sees' the handbrake being released... Not sure if my HU is a 'clever' one...
Post #262114 29th Aug 2013 10:08am
Nick-St
Glad to say, that my HU isn't a 'clever' one - handbrake line direct to earth and it thinks the handbrake is on!
Post #262214 29th Aug 2013 6:43pm
Thumbs Up WeWillWinπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
Post #262228 29th Aug 2013 7:53pm
mrd1990
Wales 2000 Defender 110 Td5 CSW Epsom Green
I just installed 2 reverse cameras and a head unit with a flip out screen. Didn't bother with the handbrake option as you'd have to be unbelievable stupid to watch a DVD whilst driving, HU seems unaffected by it.
I ran the wires (2x video, 2x power) from the rear driver side under the chassis where the trailer electrics are, tied the wires along the chassis and into the cab via the under seat box, then under the carpet and up into the dash via the fuse box (MY00 dash).
One wire connected to the reverse light and the other was for a spur off the cigarette socket that comes on when ignition is at position II>, this way I can use either camera regardless of which gear I'm in Thumbs Up
Post #262241 29th Aug 2013 8:38pm
