Home > Puma (Tdci) > Door seals...not water ingress. More ambitious than that.
Landyphil
United Kingdom 2003 Defender 110 Td5 USW Stornoway Grey
Don't laugh.
I'd like to make the Puma doors more airtight.....
Stop it!
The Td5 doors, rot prone though they are shine like a beacon of quietness and decorum within the puss filled mire of the Puma's inadequacy.
At 60mph+ the td5 with it's overdrive in is a lot lot quieter than every Puma I've been in and I'm sure it's down to the windnoise from the doortop regions.
I've fitted new door seals which made zero difference and having seen the shape of these new doors taped some thin plastic tubes to the door where it meets the seal. Huge improvement but hardly a quality fix.
I've perused many a ventilation parts catalogue as well as automotive ones for a seal the same as the current Defender design just with a taller box section to that it actually meets the chuffin door tops properly but to no avail.
Anyone found any other solutions? 90XS Tdci John Eales
110 CSW G4 Edition
88" Series 3 Racer
Post #261701 27th Aug 2013 8:21pm
Green Machine
Re: Door seals...not water ingress. More ambitious than that
I'm afraid I can't help with the door seals, but it's nice to have a wordsmith on the forum! Nice work there! Thumbs Up 2005 Td5 | 90 Station Wagon | Tonga Green
Post #261705 27th Aug 2013 8:28pm
Lou Sparts
United Kingdom 2005 Defender 90 Td5 XS CSW Zambezi Silver
Have you tried adjusting the striker plates to pull the door in tighter ? 2005 Td5 90 XS
Steve
Post #261709 27th Aug 2013 8:32pm
Nobby
England 2010 Defender 90 Puma 2.4 CSW Santorini Black
Hi I tried all the various window sealants, stick on type to no effect. Took to local Independant and they bent the top in slightly, not a great description, sounds agricultural but it worked and I can cruise at 80 before wind noise now. Also the doors still close as before.
It's how they adjusted the trim on Spitfire to get them to fly straight and level so can't be a bad thing. _______________________________
Puma Defender 90
Post #261744 27th Aug 2013 9:14pm
Norm4n
Is there adjustment on these they looked fixed
Post #261758 27th Aug 2013 9:35pm
Lou Sparts
The striker plate is the bit on the door frame (the one you catch you belt loops on as you get out) that the the door lock latches onto.
if you undo the screws that attatch it you can adjust them in or out thus pulling the door inwards if you have moved the striker inwards.
Hope this helps. 2005 Td5 90 XS
Steve
Post #261761 27th Aug 2013 9:43pm
