![]() | Home > Australia & New Zealand > In search for bigger compatible Mag Wheels |
griffman Member Since: 16 May 2012 Location: surrey Posts: 147 ![]() ![]() ![]() |
How about some Mach 5s. Mine are 10" wide, the design has changed a little.
http://mach5wheels.co.uk/model-of-vehicle/...nder-90110 ![]() Click image to enlarge ![]() Click image to enlarge If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
Glynparry25 Member Since: 16 Feb 2009 Location: Miserable Midlands Posts: 3015 ![]() ![]() ![]() |
Depends on size.......
18x8.5" from forum sponsor: ![]() Click image to enlarge http://www.overfinch.com/the-collection/defender/wheels/ 17x8" from Australia (no shipping/ import costs and very strong): ![]() Click image to enlarge http://www.performancewheels.com.au/Home/W...mp;Cat=4WD Could you supply more information on what the use will be- Bling for cruising down the road or just bigger and still capable of going off-road/ outback? Another option would be hub adapters and then fit Discovery 2/3/4 or RR wheels. Glyn ![]() ![]() |
