Home > Puma (Tdci) > How to remove the rear sliding screens |
jont Member Since: 02 Apr 2011 Location: Aylesbury, Bucks Posts: 242 |
When I looked into it for our '06 90 I was informed that I had the new-type 'glued' sort of sliding frame that can't be taken out without destroying the glass/frame ...
Had I bought a '05 or '55 it would have had the 'bolted in frame which can be unbolted and the glass remove easily for film/tinting ... So guess depends on teh age and whether you are lucky or unlucky in what they had on the shelf at Lode Lane on that day Jon |
21st Aug 2013 4:53pm |
bob neville Member Since: 30 Apr 2009 Location: Marbella Posts: 3248 |
Up to around 2005 ? the rear side windows were riveted in and relatively easy to remove. Later rear side windows are, as stated above, bonded in.
I am sure somebody will be along to tell you how to remove the bonded version soon - probably involves a sharp implement Bob 2015 Jaguar XE240 R Sport - goes like ....... !! 2013 Defender 90 CSW - sold 2009 Defender 110 Double Cab - sold 2001 TD5 90 CSW - offroad project - sold to a forum member 2011 Porsche Boxster - for the sunny days ! |
21st Aug 2013 5:16pm |
adafish Member Since: 30 Mar 2009 Location: atherstone Posts: 1384 |
...........or heat gun... I think they are in 2 parts aswell.. Putting Dreams on Drives at JLR Solihull.. |
21st Aug 2013 5:20pm |
Glynparry25 Member Since: 16 Feb 2009 Location: Miserable Midlands Posts: 3015 |
Bob:
Click image to enlarge With one of these babies you can remove the whole window assy and glass intact......... you will however need to buy some new side pannels Glyn Last edited by Glynparry25 on 21st Aug 2013 6:31pm. Edited 1 time in total |
21st Aug 2013 5:21pm |
That will certainly do the job Glyn
Just found this For bonded type: Use your stylus knife to cut the bonding between the frame and vehicle side panel. Eventually your frame will be loose and will come away from the vehicle body If in the process,the surfaces are dented or damaged, flatten them out as best you can. Clean the surfaces surrounding the aperture to remove any dirt or grease. Bob 2015 Jaguar XE240 R Sport - goes like ....... !! 2013 Defender 90 CSW - sold 2009 Defender 110 Double Cab - sold 2001 TD5 90 CSW - offroad project - sold to a forum member 2011 Porsche Boxster - for the sunny days ! |
21st Aug 2013 5:23pm |
landybehr Member Since: 17 Apr 2013 Location: -D- Posts: 173 |
@Glyn:
Well, so neednīt I remove the panels inside ? Just start cutting from outside? It looks like there is a 1-2mm thick rubber gasket between the frame and the side panel. The Window assy itself looks like it will split. Somehow "they" will have had to assemble it. What I not quite like is that service to the seals etc. looks like being a nuisance now. (though I think there is a way of replacing the gutter seals with the screens in situ). |
21st Aug 2013 6:21pm |
