Home > Camping, Caravanning and Holidays > Sankey Wide Track Trailer Upgrade
Page 2 of 5 <12345>
No, I won't bother filling in the corners - it just has to be functional. The new tyres stick out about two inches from the body, so yes, just like a Defender with spacers but without the arches.
I'm hoping that the wheel arches will also give me somewhere to hang some mud flaps, which will hopefully keep the crud off the rear legs. Darren
Post #255069 31st Jul 2013 9:34pm
stravaig
Scotland 2013 Defender 110 Puma 2.2 XS CSW Rimini Red
Any Further Forward?
I would love to see more updates on this project. Thumbs Up
I have a sankey that I plan to convert into a camping trailer. I have looked at N&J aluminium, they make a double cab canopy with side doors etc, something like that on a Sankey would be just superb.
Post #258111 12th Aug 2013 11:19am
Thanks. There won't be anything more until next month though, as I'm away on holiday for couple of weeks soon Very Happy Darren
Post #258115 12th Aug 2013 11:26am
landy andy
Hope you don't mind me interrupting your Sankey post, but I used defender rear arches on my Sankey, and if you have wheels with a hole for drive flanges to fit through, you don't need spacer, which was great for me as my wheels allowed this.
Andy
Post #258120 12th Aug 2013 11:30am
Hi Andy,
I'm guessing you've had a complete overlay panels made for each side to which the arches are fitted? If so, what are they made of and how are they attached? Darren
Post #258126 12th Aug 2013 11:39am
landy andy
All I did was buy a pair of used rear painted arches off eBay for �20, and a bag of the fixing pins. Then brought 3mm Ali panels cut to the correct length, cost was �120. I then removed the hooks from the side of the trailer, held up Ali against the side and drew around trailer. I then laid arch into the drawn void on the Ali, added 15mm then cut with jigsaw, then I cut lots of small cuts up to the original drawn arch, causing many flaps that I then bent up, giving me a flange to fix arches too. also then drew straight lines from bottom of arch to trailer corner and cut these.
To fix the arches to the side panels I used the fixing pins but also glued them on with sikaflex, to stabilise the panels. The side panels are just bonded to the trailer sides with sikaflex, and bolts now holding on the hook.
I think it is more complicated to write about this than do it, was all really simple, and makes the trailer look complete.
Hope that makes sense. Did intend to take photos but got carried away.
Andy
Post #258131 12th Aug 2013 11:57am
landy andy
Think the pics say it all
Andy
Post #258132 12th Aug 2013 11:59am
Thanks. I guessed it would be something like that Thumbs Up Darren
Post #258135 12th Aug 2013 12:18pm
Caterham
LRA- looking good.
simple question if you don't mind. how do you get the brake fluid cap off ?
and one other thing......the trailer above which has the drop down tail on chains - would like to do this to mine. does anyone have some close up pictures to show how its been done and using what. (I know its not the most difficult thing but if someone has already done this successfully it would be easier just to copy....or should I say cut and paste ?
Post #259809 19th Aug 2013 10:30am
Thanks. The cap just unscrews... Confused Darren
Post #259891 19th Aug 2013 3:26pm
Caterham
Embarassed Confused
hmm. I'll have to try that again.....I have a horrible feeling I've been trying to pull it off ......
(although I've not tried for a while I think the idea of unscrewing it for some reason didn't come into my head Embarassed )
Post #259893 19th Aug 2013 3:28pm
Ah, i understand your question now. The cap does have a large rubber cover on that might suggest it just pulls off. However, underneath is a regular plastic screw cap.
The exposed plastic reservoir is one of the few weak points of this trailer. Eventually, the sun gets to them making them brittle. Most of mine is now covered by the A frame 'deck' but I do plan to make a simple cover for the top to stop it getting knocked. Replacement reservoirs are available for about �30, although the cylinders themselves are very difficult to replace. Darren
Post #259903 19th Aug 2013 4:50pm
johnnyd
How much will a trailer like this cost me, I can't see many Sankeys on ebay at all?
JD
Andy
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  2008 TDCi 2.4 XS CSW
Post #260010 20th Aug 2013 8:37am
landy andy
I paid �400 for mine, Thumbs Up
Post #260012 20th Aug 2013 8:40am
johnnyd
Is that new or second hand, or are they not made anymore ?
JD 2008 TDCi 2.4 XS CSW
Post #260013 20th Aug 2013 8:45am
Page 2 of 5 <12345>
