Home > Maintenance & Modifications > Diff lock light
big steve
United Kingdom 2015 Defender 90 Puma 2.2 HT Montalcino Red
Diff lock light
My diff lock light is on but is it in diff lock
I'm a bit snookered on this as I have a Ashcroft atb so I can't just lift a wheel !
And good ideas ?
Steve 2015 2.2 tdci hardtop xs
3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P
hybrid turbo in build -done ready to fit
ashcroft atb in transfer box
6 speed auto in build
Post #259395 17th Aug 2013 2:37pm
Get on some loose gravel like a car park. (really loose I mean) and pull away fast in low gear. I'd have thought you could tell if only one wheel was spinning. If the fiff was locked then you should have no wheel spin or little. TheThunder RollsπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
β›½οΈπŸ›’οΈβš™οΈπŸ§°πŸ’ͺ
Post #259396 17th Aug 2013 2:40pm
Glynparry25
Again, his ATB would stop that.
See if you can independently turn the front/ rear prop shafts (depends on much play you have).
You could remove the end of a prop shaft and see if it will turn without the other (Transfer box end).
Or (if you can) lift all 4 wheels off the ground and with it in Neutral see if you can turn the props independently.
Another option is to take the inspection cover off the side of the transfer box and see where the collar is.
Just a couple of ideas.
Glyn Dog Sheep
Post #259402 17th Aug 2013 3:08pm
Sockpuppet
Doesn't the hand book say driving in reverse in a circle should sort it out.
Post #260199 20th Aug 2013 9:30pm
