Home > Technical > Transmission Fluid Weeping -easy fix?
Vizsla
While under the 90 yesterday, doing a bit of a clean ahead of applying Dinitrol / POR15 next week, I noticed what appears to be a weeping of clutch fluid between the two halves of the bell housing.
I'm not a mechanic so I hope I have this right, but hopefully you can see on the picture where I mean (this is after I cleaned the oil away). Its weeping through the seam and not the drain plug on the left hand side.
Is this likely to be because of fluid overfill at the factory? the truck is coming up to three years old, 17,000 miles only and as far as Im aware (we are not the first owners) it will not have had any work done on the clutch etc and no change of fluids required in the maintenance schedule.
Is it likely to be a simple remedy of tightening the bolts, adjusting the fluid to the correct (2.2l?) level if overfilled and job done or is there a possible need to replace a seal or something?
Its booked in to the local LR dealers for inspection next week and I want to make sure I ask the right questions Embarassed
Any help gratefully received.
I should add that I have no other issues with gear selection (other than the usual 1st to 2nd slight resistance) so no apparent misalignment of gears etc and the clutch is fine as the truck gets very light use)
Thanks,
Paul
Post #259079 16th Aug 2013 9:16am
Happyoldgit
If it is indeed hydraulic fluid then the clutch slave cylinder seals are the likely candidate, to get to the cylinder on a Puma means a gearbox out job. I would check the fluid level in the clutch master cylinder reservoir and monitor accordingly. Sure it's not oil? Steve.
http://forums.lr4x4.com
Post #259096 16th Aug 2013 10:58am
pope10001
United Kingdom 1992 Defender 90 200 Tdi HT Zermatt Silver
It could be the clutch slave cylinder which is inside the bel housing somewhere and requires the gearbox removing to replace. So definitely get it done under warranty whilst you still have it.
Regards,
Mark
Post #259097 16th Aug 2013 11:00am
pope10001
DOH! Beat me too it. Bow down Rolling with laughter
Post #259098 16th Aug 2013 11:01am
Vizsla
Thanks both Thumbs Up
Just did a bit of reading up on this after you posted and it certainly sounds like it is unfortunately the CSC. Its definitely not engine oil (too clear and not viscous enough). What a pain if its gear box removal time and with so little mileage Crying or Very sad
Its going to the dealers this afternoon now, which is only a few miles away, so they can get it up on their lift & take a good look. I'll feed back what they say.
Good job I spotted it while still under warranty I suppose.
Paul
Post #259107 16th Aug 2013 11:35am
Vizsla
Embarassed Embarassed Embarassed Embarassed Embarassed Embarassed Embarassed Embarassed Embarassed Embarassed Embarassed Embarassed
Guy Salmon at Ascot were extremely helpful and have calmed my fears of a transmission fluid leak - it was in fact condensate from the air con Rolling with laughter Felt a bit silly but better safe than sorry Embarassed
Apparently the AC vents above the gear box housing and was dripping exactly around the point at which the two bell housing halves meet and looks just like a leak when its just a small amount. Laughing
Having run the air con fully on for a half hour journey and reinspected there is a lot more fluid (obviously) now dripping around that point and its clearly water not oil.
Few!!
Time to now get on with protecting the underside as intended and say sorry to 'Ermintrude' for doubting her reliability Mr. Green
Post #259156 16th Aug 2013 3:55pm
