![]() | Home > Td5 > Mudstuff dash |
mobilecentre Member Since: 05 Mar 2012 Location: Evesham Posts: 645 ![]() ![]() |
Built a few dashes with Carling switches
![]() Click image to enlarge The killer is the time to do it properly including a diagram and key with wire colours and functions etc |
jerseyman Member Since: 21 Jul 2009 Location: Jersey Posts: 279 ![]() |
Tim, the water marking you are adding to your photos is making them pretty difficult to view.
It is automated I am afraid - I will ask them to see what we can do.
Stoney Member Since: 28 Sep 2012 Location: Hampshire Posts: 87 ![]() ![]() |
Sorry to bring up an old thread but thought it was better than starting a new.
I have the mud console and I am about to order the carling switches for it I want to use the plugs for the switches to make it easier to un plug later on. Do any of you know if I have my radio say in the top angled slot then the switches below, if with the plugs on it will clear the radio ? Or will it work with switches up top then radio below ? I am putting my cb right at the bottom Thanks guys |
Inigo Member Since: 13 Nov 2011 Location: Kent Posts: 623 ![]() ![]() ![]() |
The radio clashes with the plugs for the switches. I had to put the radio at the bottom and the CV at the top. It is still fiddly to remove the plugs.
The OP got it to fit... (Page 1) An engine to TDi for! "Land Rover- Proudly turning drivers into mechanics since 1948" ![]() |
I will order the bits and if so the cb will have to go up top.
I sore the OP but I didn't know if he had used the plug on the back of the switches. Once I have got it to fit I will let you know how or if it works Thanks again guys |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5884 ![]() ![]() ![]() |
I'm 99% sure I did use the black plugs at the back of the switches. I think if I did it again, I would drop the switches down by about 5mm to give a little more clearance 1999 Defender TD5 110
Thats great thanks excossack, Another job to add to the list !
