Home > Maintenance & Modifications > batteries
Page 2 of 2 <12
ZeDefender
Got all the gear but still need to fit my setup - 2 PC1500s and BlueSea kit (Mobile Centre).
A bit expensive to have sitting in the garage but so far I've been too chicken to start the job Embarassed Rolling Eyes Tell someone you love them today because life is short.
Post #258512 13th Aug 2013 11:53pm
ericvv
Question about battery terminals. I read on the Odyssey website that different batteries have different terminal connector types.
For instance the PC1500 which is named here has "SAE" or "SAE and 3/8”Stud (Pos.) 5/16” Stud (Neg.)" or " TOP SAE
SIDE 3/8” Receptacle" terminal connectors.
The PC1700 then again has "M6 Receptacle†or SAE 3/8” Receptacle" terminal connectors.
The PC1350 has "DIN lead post" terminal connectors.
Which terminal connectors are used in our Puma on the original ex factory Land Rover Varta single battery?
Hope it is the same DIN lead post as on the PC1350, as that is the one I am interested in to replace my original Varta. (No need for dual battery in my case)
Tks, Eric You never actually own a Defender. You merely look after it for the next generation.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #258521 14th Aug 2013 6:19am
The standard configuration is the SAE type, which comprises two slightly conical studs of 3/8" and 5/16".
The PC1350 won't fit without altering the connectors on the cables, I'm afriad. Darren
Post #258538 14th Aug 2013 7:16am
ericvv
Post #258549 14th Aug 2013 7:33am
ericvv
MichaelHead wrote:
Ericvv replace with genuine mines 7 yrs old still going strong most other batteries only offer 4yr warranty
Found an old thread on this subject, and tatra805's extensive comments seem a wealth of educational information. After absorbing all this, seems LR made a pretty educated choice for their OEM battery in the Puma. Don't see much reason for replacement to look further than that same one anymore, both for quality and price. Thumbs Up
http://www.defender2.net/forum/topic16605-15.html You never actually own a Defender. You merely look after it for the next generation.
Post #258668 14th Aug 2013 5:37pm
ZeDefender
Quick update and encouragement to others perhaps:
Took me about 5 hours in total, of which 1 hour was spent drinking tea and scratching my head (there goes more hair Rolling Eyes )
I also left the underseal to dry a bit for an hour (covered bottom of battery box and underneath with it).
The only problems I had were:
a) with my setup, one of the + battery terminals is jammed under the top of the seat box sides - you can see where I've jammed a black plastic panel to make absolutely sure there are no shorts.
b) I needed to remove the original earth connector and crimp on a ring terminal. I was expecting it to be 35mm2 but it's a tiny bit larger (probably some LR non-standard size) - botched it for now - hopefully the 50mm2 terminals will arrive soon Thumbs Up
Big thanks to bpman for all his help and of course Tim at mobilecentre for providing the raw materials Bow down
Matt
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Tell someone you love them today because life is short.
Post #269848 27th Sep 2013 8:39pm
Jim_Bean
Hey ZeDefender - could you re-post your photo? I'm trying the same set up and would like to see it.
Thanks Thumbs Up
Post #334386 29th May 2014 2:09pm
ZeDefender
Sorry - confused... is it not visible in the post above? Was there another photo? Confused Tell someone you love them today because life is short.
Post #334456 29th May 2014 7:25pm
Jim_Bean
Thanks, yes it's there now. Earlier there was just a 'photobucket' placeholder and no image Shocked
All good now. I'm putting the same setup and just wanted some visual cues as to how you had installed everything.
Thanks Thumbs Up
Post #334484 29th May 2014 9:12pm
couplands
United Kingdom 2001 Defender 90 Td5 HT Oslo Blue
There is a good article here about fitting a twin battery setup...
http://www.mobilecentre.co.uk/images/Data_...ue_Sea.pdf
Simon
Post #334490 29th May 2014 9:26pm
Jim_Bean
Thanks couplands. Thats the one i'm trying to build. Its just useful to see as many photos as possible before mounting the really and fuse box to see where other people have had success.
I'll go have a read... Thumbs Up
Post #334531 30th May 2014 7:28am
Maxxed_Ross
Scotland 2001 Defender 90 Td5 CSW Cobar Blue
that was a very useful article, thanks for posting it Very Happy
Post #334536 30th May 2014 8:15am
Page 2 of 2 <12
