![]() | Home > Td5 > Mudstuff dash |
WarPig Member Since: 04 Dec 2009 Location: Sheffield Posts: 1748 ![]() ![]() ![]() |
It's a shame that carling switches are made upside down. Up for on and down for off !
I think the Mericans are to blame. I'm guessing they are made in the USA?
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2693 ![]() ![]() |
The ones that ARB supply with their lockers (which are based on the Carling ones) operate in what we would say is the "normal" way, ie. press down for on.
Standard Carling switches operate up for on, which is strange. Can always turn them upside down, though then the label is at the bottom. |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5884 ![]() ![]() ![]() |
The label at the bottom isn't an issue for me. 1999 Defender TD5 110
mobilecentre Member Since: 05 Mar 2012 Location: Evesham Posts: 645 ![]() ![]() |
Carling make UK spec switches specifically for us which are the "right" way round
![]() ![]() Click image to enlarge Down for on - bar illuminates when on - square illuminates green for legend http://www.mobilecentre.co.uk/index.php?ma...ath=60_195 |
Cheers. Well, when I come to populate the mudstuff dash pod, I might consider them(as being the right way round) 1999 Defender TD5 110
I didn't know that. I might order a replacement set from you for my console. ![]() Click image to enlarge Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() |
You could of course turn the switch upside down ....
....you could but the pre-labelled switches would have the logo upside down. 1999 Defender TD5 110
Pre-labelled ? - I assume you mean the ARB difflock switches ?
Edit: Seen your first picture now. |
Them ones! 1999 Defender TD5 110
Yes it can |
All the rockers / actuators we do are genuine Carling rockers with Legends on from the factory rather than the transfers you rub off a sheet. Here is a sample below
[quote="WarPig"]
You can keep your rockers / actuators and just order the switches - all the suppliers such as MUD, X-ENG etc order the standard range of switches from Carling which is the US spec so exactly the same switch in terms of features function and spec but they can get them off the shelf quickly from a distributor here in the UK but they are up for on. Here is an article we did a few years back on Carling Switches http://www.mobilecentre.co.uk/images/Data_...itches.pdf |
