Home > For Sale & Wanted > FS - FCX Safe - SOLD |
davew Member Since: 02 Jan 2012 Location: North Yorkshire Posts: 888 |
I'd be interested in this, can you confirm the internal dimensions of the box as it looks a bit small but that might just be the camera angle/lens ? http://www.yorkshireoffroadclub.net/
12th Aug 2013 4:13pm |
smb Member Since: 15 Jan 2013 Location: Cheshire Posts: 1232 |
No Problem. I will measure it tonight and let you know
12th Aug 2013 4:15pm |
Go Beyond Member Since: 30 Jan 2012 Location: Headcorn, Kent Posts: 6678 |
Sizes are on the website
http://www.farrowsclassics.co.uk/fcx-EXPEDITION-LOKBOX.html |
12th Aug 2013 4:23pm |
pjb Member Since: 08 Apr 2009 Location: Sunny Oxford Posts: 1244 |
ex website
The 'fcxEXPEDITION LOKBOX' was designed to be 'hidden' by being fitted into the floor of a Defender in the front on the passenger or drivers side (under the mat) BUT it can be installed into any vehicle - front or rear floor, top of seat box, rear bulkhead, custom rear box etc - limited only by your imagination (and the space available) The internal measurements are 270mm x 200mm x 120mm, the 'lip' (which is predrilled for the supplied rivets) is 340mm x 275mm 2020 P300 HSE |
too slow ! 2020 P300 HSE
12th Aug 2013 4:24pm |
DaveW,
Measurements are as follows: Upper frame(the bit that you rivet to the floor): 340mm x 270mm Lid: 245mm x 185mm Internal Box: 265mm x 190mm x 105mm Total Depth: 112mm Hope that helps Steve |
12th Aug 2013 5:20pm |
Thanks Steve, PM on it's way shortly http://www.yorkshireoffroadclub.net/
12th Aug 2013 6:17pm |
Dave, Excellent. pM on its way. Cheers Steve |
12th Aug 2013 6:45pm |
Now sold
13th Aug 2013 1:17pm |
