Home > Puma (Tdci) > timing chain tensioner problems?
dgardel
Italy
from blacklandy.de
3 cases about engine damage due to the broken timing chain tensioner. There is a modified hydraulic tensioner and a modified version of guideway, if possible, so you can swap out warranty or before long journeys.
Incidentally noted that the timing pin (LT workshop manual) may not be used to contact the crankshaft (fits into various positions)
no infos/knowledge from the stealer Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #257694 10th Aug 2013 8:49am
