Home > Td5 > New fuel Pump
DRW58
Scotland 2001 Defender 90 Td5 SW Epsom Green
New fuel Pump
What do we know about fuel pumps?
My TD5 apparently needs a new one having been sucking air and stopping the engine. Big Cry
How much will this cost me.
I had a look on the tinternet this afternoon and was shocked at the price differences and at how much some of them cost.
How can these fundamental parts be so expensive? it's a pump for goodness sake. Big Cry
I'd be interested to hear your experiences. Thumbs Up
Dave I built a garage for my Mini
With a place for everything and everthing in its place.
Ten years down the line there's a Mini in there somewhere, and Censored all's where it should be!!!! Ho hum
Post #257295 8th Aug 2013 4:56pm
The Td5 pump is a submerged 2-stage pump and is fairly high pressure. It is more complex than many and this is reflected in the price.
Are you sure it's the pump at fault? A leak in the low-pressure circuit or filter could conceivably be the problem.
Post #257296 8th Aug 2013 5:01pm
mk1collector
I changed mine at a cost of (part only not fitting) £475!! And then found out it was the injector seals and washers that cost peanuts so it might be worth changing those first Thumbs Up
Post #257297 8th Aug 2013 5:07pm
Lou Sparts
United Kingdom 2005 Defender 90 Td5 XS CSW Zambezi Silver
We had exactly this problem on a disco 2 Td5 at work, turned out to be injector seals and "O" rings. Woth a look. 2005 Td5 90 XS
Steve
Post #257302 8th Aug 2013 5:25pm
If/when you do buy a new pump... the "defender" ones are always £100 or so more expensive than the discovery spec ones.
But... the only difference is the float arm... and it just unclips. so save youself some money, get the disco pump, and spend about 30 seconds unclipping the defender arm and clipping it to the new disco pump Thumbs Up
Post #257419 9th Aug 2013 6:53am
Diablo
1984 Defender 90 200 Tdi SW Keswick Green
I might have one I took out of a TD5 tank going spare....
Post #257436 9th Aug 2013 8:03am
DRW58
Thanks everyone, I've sent it out to Tayside Landrover and Matthew Webster has ordered a pump for me so I'm kind of waiting with bated breath to see how much it's going to cost.
The shooting season is just round the corner and what I don't need is unreliability,particularly if as occasionally happens someone needs to move my vehicle.
if I'd realised it could have been this expensive I would have had a look myself on the basis that all the nuts and bolts have just been out for the chassis replacement so it would have been straight forward. Big Cry
Thanks Diablo someone else will no doubt need your pump.
Regards to all DRW
Have a good weekend I built a garage for my Mini
Post #257575 9th Aug 2013 5:41pm
Laurie
I bought a Bearmach one last year.
Swapped it for a genuine part after the noise drowned the engine!
Post #257661 9th Aug 2013 11:51pm
achuakh
Singapore 2002 Defender 90 Td5 SW Oslo Blue
The oe pumps that i fitted seem to be noisy after I swapped mine. But it's been running for over 3yrs. So I'd say, if noise is the problem, then buy original, if not, stick with what works. From the land of the most expensive land rover defenders on planet earth. At �125k for a XS 110 csw and you get to own it only for 10yrs! Please find me a good reason to stay on this island.
Post #257664 10th Aug 2013 5:37am
DRW58
Pump Update Triggers Brush
Matthew fitted a genuine article, and recommended a new fuel line too, he thoughtfully passed his discount on to me so the whole job was £560 or so including labour and VAT.
So as the title says my TD5 is starting to take on the characteristics of triggers brush Very Happy
£7k plus and counting this year. Whistle
I bought it as a long term "investment" knowing I'd need to spend money on it, now the main issues have been addressed I want to start on some non essential upgrades spending a little each month leaving enough in the bank balance to keep Swmbo in the manner to which she has recently been accustomed...................Hungry Rolling with laughter
Ok it's late I need to go out and lock the Landy just in case Thumbs Up
DRW I built a garage for my Mini
Post #258712 14th Aug 2013 9:00pm
Macpaul
United Kingdom 2013 Defender 110 Puma 2.2 USW Loire Blue
I've spent about the same, NOT intending it to be a long term hold but it's turned out that way.
Following the collective wisdom on here in a recent post, http://www.defender2.net/forum/topic22331.html
a fuel pump is my next er, investment, and I'd been looking at VDO units which I thought were OEM at about £250 retail.
Is this right and has anyone used them?
Post #258717 14th Aug 2013 9:24pm
keith
When the fuel pump packed in on my TD5 the LR engineer asked where I drew my diesel from . When I told him " Tesco " he shook his head and told me that was the problem and never use it again . That was 7 yrs ago and BP Ultimate ever since .
Post #258721 14th Aug 2013 9:43pm
