Home > Td5 > Mudstuff dash
Page 1 of 3 123>
excossack
Mudstuff dash
I have finally got around to cutting the holes out for the bank of Carling switches,..But I cut out the wrong section. Big Cry Big Cry
See picture
The switches should have gone at the bottom of console and the radio at the top on the sloping part.
Question. The radio will fit in the section where the switches are now and I can move the switches below. But if I was to have the radio where the switches are now, is there enough room in the dash to take this?
[/img] 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #257365 8th Aug 2013 8:45pm
Retroanaconda
You'll have to chop a section out of the lower dash to let the radio fit, but it will work other than that.
Post #257367 8th Aug 2013 8:53pm
Killer90
Site Sponsor
Loads of room behind there Thumbs Up but youll have to cut part of the dash away with a grinder Thumbs Up CSK Automotive
www.cskautomotive.co.uk
Post #257368 8th Aug 2013 8:54pm
excossack
Cheers chaps. The chopping of the dash is the PITA...but...oh well out with the grinder...
This time I must be careful and not to cut into my knee with the grinder like I did a few years ago... 1999 Defender TD5 110
Regards
John M0VAZ
Post #257371 8th Aug 2013 9:00pm
Killer90
Site Sponsor
Laughing Laughing Mini Hacksaw might be your best bet then Whistle Thumbs Up CSK Automotive
Post #257373 8th Aug 2013 9:02pm
excossack
I think so. I was lucky, just missed the knee cap! 1999 Defender TD5 110
Regards
John M0VAZ
Post #257376 8th Aug 2013 9:11pm
There is no need to use a grinder, a hacksaw is suficent, it's only a thin gauge steel Thumbs Up
Post #257449 9th Aug 2013 8:48am
excossack
Thats better! I have a hacksaw Smile 1999 Defender TD5 110
Regards
John M0VAZ
Post #257457 9th Aug 2013 9:09am
Also, the majority of people who install these dashes put the stereo at the bottom, take a look at MUDS website for pictures.
Take your time, put some masking tape on the dash where you are cutting so that you can draw a line to cut to.
Make sure there are no stray cables behind where you are cutting.
It doesn't have to be the neatest cut in the world, you won't see it but when you've finished protect the cut metal edge with paint to stop it rusting and then gaffer tape folded over it to protect cables from the sharp edge Thumbs Up
Post #257459 9th Aug 2013 9:15am
excossack
I am going to attempt to mount the stereo at the top for the reason of: If (when) I get new stereo with a flip out screen it will obscure the buttons. But if i have to mount it at the bottom I will. 1999 Defender TD5 110
Regards
John M0VAZ
Post #257703 10th Aug 2013 10:13am
excossack
Right update...
Got the Mudstuff dash mounted with the metal frame all screwed up and the moulded dash on.
Looks good. Except for
When in 1st & 3rd gear the gear stick just touches the lower part of the mud console.
The radio in the top slot does not fit in fully, it sits about 1" proud of the mud console. So now I have three options
1. Remove the rear metal section of the mounting plate and cut out a section the plastic panel behind that to make more room
2. Move the radio to the bottom and the Carlings to the top.
3. Leave the radio sticking out.....(not really) 1999 Defender TD5 110
Regards
John M0VAZ
Post #257816 10th Aug 2013 9:17pm
Retroanaconda
That's why my radio is in the bottom of mine. To accommodate the length.
The only issue is sometimes, very very rarely, I hit the station change buttons with my hand when changing gear "enthusiastically". Gear lever itself is nowhere near though so that's OK.
Post #257892 11th Aug 2013 11:00am
WarPig
I've heard of some folk removing the gear stick and putting a slight bend in it to stop it hitting the console.
Post #257915 11th Aug 2013 12:15pm
excossack
Finally got it fitted. Managed to get the radio in the top and switches below and so far not had to cut out the dash.
Just need to sort out the wiring and sort out the wiring for the rear/wash wiper as I can get the wiper to wipe but no washer.
What I would like to do is have it so the switch is on when pressed in at the bottom and not the other way around.
More fiddling needed, but for now it will do.
I will see what its like to drive and see if I catch my fingers on the lower part of the dash. 1999 Defender TD5 110
Regards
John M0VAZ
Post #257925 11th Aug 2013 1:03pm
jont
2006 Defender 90 Td5 XS CSW Santorini Black
Nice ... only wish Mudstuff did a replacement unit for the late (2006) TD5 - I've the XS with the silver/grey cover and switches above and to the side of the radio hole ...
They do a screw on cover panel which would at least provide a flat surface to mount the double-din cage too
but will still have to attack it *and* the main panel with the Dremel to cut the slot bigger Confused ... and it's black as oppose to the silver finish on my dash Big Cry
...can't seem to find any spares and even ERC in the USA who did some custom installs won't make/sell any Sad
Surely a gap in the marketplace and sales opportunity for Killer90 after his gorgeous Puma dash's ? Thumbs Up
Jon
Post #257931 11th Aug 2013 1:21pm
Page 1 of 3 123>
