![]() | Home > Td5 > s220 |
Porny Site Sponsor Member Since: 31 Aug 2009 Location: Sutton Coldfield - West Midlands Posts: 809 ![]() ![]() |
I've fitted lots of them...
As they were my turbo (along with the whole other range of bolt on VNT replacement turbo's), developed for me by Turbo Technics. BAS is also able to sell them (as we agreed this at the time) - but he is the only other authorised distributor. Everyone else that sells them is mealy buying them off myself or Pete. No one else had any input in their development, testing, tweaking, etc. And if they say otherwise they are lying.... and this does show up in the set up at times. This is a great turbo, and with a dual channel limiter box, high quality intercooler and exhaust make for an excellent conversion with matched mapping. Ian IRB The home of the first modified Keswick Green 90 - and the first 2.4 Puma through both the 200bhp and 550Nm barriers. www.IRBdevelopments.com www.facebook.com/irbdevelopments www.integrated316.com www.facebook.com/integrated316 Last edited by Porny on 2nd Aug 2013 9:22am. Edited 1 time in total |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6124 ![]() ![]() ![]() |
What's so special about this turbo Ian?
adafish Member Since: 30 Mar 2009 Location: atherstone Posts: 1385 ![]() ![]() ![]() |
comes in a BIGGA BOX....
The S220 turbo has a different compressor wheel, compressor housing and exhaust wheel to the smaller S208 turbo (which has the same max flow as a standard turbo - just with much nicer characteristics).
Basically more flow (volume) without increasing boost. Ian IRB The home of the first modified Keswick Green 90 - and the first 2.4 Puma through both the 200bhp and 550Nm barriers. www.IRBdevelopments.com www.facebook.com/irbdevelopments www.integrated316.com www.facebook.com/integrated316 |
Oh OK. so better or worse than the VGT i've got from you? or just "different"??
Just for different applications... The S208 (as per yours) is designed for mildly tuned Td5's and offers a massively improved pick from low RPM and mid range. When the VNT mechanism is fully open, the max flow of the turbo is very similar to that of a standard fixed geometry turbo. However, what it does do is offer much better drive-ability. However, max BHP will not increase over a standard turbo. What it will do however is change the torque curve and characteristics - which is where the biggest difference comes. However, the S220 - with the the larger compressor wheel/housing - allows more flow for a given boost pressure. The S220 was designed for greater power outputs - and improve performance. Commonly classed as a 'hybrid' - if you are after increased power outputs (typically 180bhp and 430Nm upwards) this is the turbo for you - but still with great low range and mid-range drive-ability. The most I have seen is 235bhp and 535nm running this turbo and other modifications. Ian IRB The home of the first modified Keswick Green 90 - and the first 2.4 Puma through both the 200bhp and 550Nm barriers. www.IRBdevelopments.com www.facebook.com/irbdevelopments www.integrated316.com www.facebook.com/integrated316 |
ironman19 Member Since: 17 May 2013 Location: cambridge Posts: 7 ![]() ![]() |
fitted the turbo.....WOW......what a difference. The sound is amazing and teh power is something else. Would highly recommend to anyone who wants, as Jeremy Clarkson puts it POOWWEEEEERRRRRR
Will.I.AM Member Since: 16 May 2013 Location: Hertfordshire Posts: 419 ![]() ![]() ![]() |
hello, what is the total cost all in and delivered for this turbo??, Also what pressure does it run with, i may be putting an order in[img]
another question, what is the difference between the 208 and the 220, i have reading up a bit and it seems in theory that the 220 will have greater volume of air but will have a great lag than a 208. what would give the overall best performance and least lag, without pressuraing above 1.2 bar?
