Home > Tdi > PTFE On Plug Threads?
shaggydog
After a wet weekend of cleaning the underside of my chassis and engine to try and find the source of my oil leak, I noticed the gearbox had been leaking between the transfer box and itself. Great...
Anyway, I figure once the engine is out to drop the gearbox and transfer box, spilt them and renew all the seals. That way all engine components will have new fresh seals which should be good for at least 20 minutes.
In the meantime though, gearbox needs topping up which I did per the usual manner.
I was so into it I was on auto pilot and screwed the plug back in with a few wraps of PTFE around the threads as I do with all sealing plugs.
Is this advised or is it going to be detrimental?
I can whip it out and scrape it off again if it is, but otherwise is it such a bad thing?
Your thoughts?
Post #254103 28th Jul 2013 2:17pm
Lou Sparts
United Kingdom 2005 Defender 90 Td5 XS CSW Zambezi Silver
Can,t see it doing much harm myself. 2005 Td5 90 XS
Steve
Post #254104 28th Jul 2013 2:20pm
GUM97
I can't see any harm in that at all. Polytetrafluoroethylene (PTFE) is non reactive IIRC, so there should be no problems with contamination etc. Thumbs Up An engine to TDi for!
Post #254105 28th Jul 2013 2:23pm
shaggydog
Didn't Think So!
Thanx Guys!
Post #254126 28th Jul 2013 4:55pm
LR90XS2011
ptfe tape in plumbing is generally used on tapered threads to seal any imperfections in the male and female thread faces, most plugs on cars have parrallel threads and a copper washer or recessed o ring to perform the seal, on a parallel thread the ptfe tape wont do much and will probably get pushed off the plug as it goes in the hole. If it wasnt fitted new its probably not required and if you have a leak past the treads a proper sealant like the ones loctite do would probably be more appropriate. There is also a chance that as PTFE reduces friction you could end up over torquing your plugs DEFENDER 90 TDCI XS,
Post #254150 28th Jul 2013 6:03pm
Caterham
if I'm not mis taken the transfer box is a tapered thread so perhaps this is a good thing you've used so ptfe.
its what I was going to do but the dealers replaced the plug and it seems to have sorted the problem I had.
Thumbs Up
Post #254178 28th Jul 2013 6:58pm
Diablo
1984 Defender 90 200 Tdi SW Keswick Green
I've stopped a few leaks in my transmission with it before.
Post #254347 29th Jul 2013 12:36pm
Skye_Rover
Scotland 1998 Defender 110 300 Tdi CSW Cairns Blue
I always PTFE the filler/level/drain plugs on my customer cars. Never had a problem, as the plugs are rough & tapered anyway, but you have to be rigorous in removing all the old thread and re-wrapping it with new when you take the plug out, otherwise the old tape gets everywhere inside the housing.
Advantage of taping is that the plug is easier to remove at the next service point, which means less likelihood of a damaged thread. The taper plugs seem to be "sticky" enough when they are done up, not to drop out on the road. Roads? Where we're going, we don't need roads.
Post #263025 1st Sep 2013 10:54pm
