![]() | Home > Technical > Air con retro fit |
Zinke Member Since: 27 Jan 2009 Location: Scunthorpe Posts: 670 ![]() ![]() ![]() |
As far as I know its not really possible on the
later dash TD5 as the older unit that used to take up the dash tray won't fit and work with the switches in the middle of the dash. Anything is possible but will mean a lot of work and will cost a lot of money. Pete. |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4800 ![]() ![]() ![]() |
Air con works like the heater matrix but in reverse, if you could get the cooler matrix into the air path between the wing top inlet and the heater box then in theory you could yes, would be serious diy though
![]() 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
