![]() | Home > Puma (Tdci) > Puma Engine Oil alternative suppliers than LR |
Tony_Hillerby Member Since: 03 Feb 2008 Location: Inverurie Posts: 36 ![]() ![]() ![]() |
Trevor
Just looked at the Castrol website at Magnatec 5W-30 and it states the following Castrol Magnatec combines Intelligent Molecules with fully synthetic technology for a stronger layer of protection. Castrol Magnatec keeps your Ford car at its peak for longer. Under its approvals it states Meets Ford WSS-M2C913-A This is differant to the 'B' you have quoted. If you go on the 'Which oil should I use' it does state the Magnatec 5W-30 to use for the 2.4 defenders One thing to note is that it says this is a fully synthetic oil and the Morris says Semi Synthetic. I have also seen Comma oil with the same spec and this was Semi Synthetic. What is Landrovers oil Semi or Fully synthetic? How can the 2 of these Semi and Fully synthetic meet the same standard? Over to you oil Boffins Tony |
Intelligent Molecules - Now there's a thing
Trevor Wright Member Since: 11 May 2008 Location: Essex Posts: 87 ![]() ![]() ![]() |
Hi Tony - seems Castrol have a muddle on their website(s) as when I looked here: http://129.35.64.91/bpglis/lubtds.nsf/tech...enDocument which is a datasheet you can call up from the main Castrol site, it quoted the "-B" standard. Trevor Wright '08 90 TDCi/TD4 XS SW |
mrwoo Member Since: 03 Jan 2008 Location: Cheshire Posts: 281 ![]() ![]() ![]() |
I use Fuchs Synthetic oil which meets Land Rover / Fords spec : WSS-M2C913-B
It is a very good brand that is generally used by high performance car drivers. http://www.opieoils.co.uk/p-991-fuchs-tita...e-oil.aspx Thanks Rich... ![]() |
CapeLandy Member Since: 21 Jul 2008 Location: Cape Town Posts: 558 ![]() ![]() |
Here in RSA this oil spec seems a little suited more for colder climates, besides we can't get it here other than Landrover Agents.
I tried Castrol RSA but their answer was to rather buy from the dealers to maintain warenty and that's that. I am sure after warenty we would require the same oil as most Landy owners service their own rigs to stay away from our awful stealers here. Castrol RSA don't seem interested in the possible market here ![]() Are any of you able to get the proper stuff off the shelf in the UK and what price? LR want about R100 per liter. James Puma 110 - gone Series III 1973 - going strong |
Natlas Member Since: 20 Mar 2013 Location: West Sussex Posts: 460 ![]() ![]() ![]() |
I have just been directed to this site, opieoils.co.uk who recommended http://www.opieoils.co.uk/c-1300-wss-m2c-934-b.aspx for the new 2.2 Puma. They also list an oil for the 2.4. but you will have to look that up as I didn't want that one. Hope this helps.
John. 2.2 90 XS 88" Series One Old Norton ![]() Minerva |
Reply is 5 years too late and minus the Puma in the mean time
![]() Series III 1973 - going strong |
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4547 ![]() ![]() |
I used this for my latest oil change in the Puma. Meets the Ford specs you require. Great price and free delivery too.
http://www.micksgarage.com/proddetails.asp...p;pk=45E14 Full specs here. http://total-gbr.lubricantadvisor.com/advi...2f5afe4d02 Oil search engine here. http://total-gbr.lubricantadvisor.com/ 1982 88" 2.25 diesel 1992 110 200tdi csw -Zikali 2008 110 2.4 tdci csw-Zulu 2011 110 2.4 tdci csw-Masai |
wmca Member Since: 15 May 2013 Location: Brisbane Posts: 26 ![]() ![]() ![]() |
In AU I use Mobil 1 full synthetic 0-30, expensive but seems to work in all climates. WMcA Brisbane Australia
Defender 2.4 Puma 2009 “Airbags! The other vehicle is my crumple zone!" |
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2622 ![]() ![]() ![]() |
Please note that WSS-M2C913-B has been superseded by WSS-M2C913-C --
2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged ![]() ![]() Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
nickhodgson Member Since: 08 Dec 2009 Location: Zambia Posts: 172 ![]() |
I use Castrol Magnatec A5 Professional 5w30 that has compliance to M2C913-C
Nick, how much are the stealers charging per litre? If you want to save some bucks, get the Motorcraft oil from a Ford dealership, it's the same oil but much cheaper. -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged ![]() ![]() Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
william8 Member Since: 03 Apr 2013 Location: Motherwell Posts: 259 ![]() ![]() ![]() |
... and i thought oil was oil
Naks, I got it at Castrol in Namibia. Cant remember how much though, was just happy to have something with M2C913 written on the container!!
