Home > Puma (Tdci) > Help with Td4 110 |
Morea Member Since: 20 Jan 2011 Location: Asturies Posts: 201 |
Hello. Was to ask for your advice. I have Defender 110 Td4 2.4. Tyres 35/12.5R15. -32 Offset. This EGR rescheduled and canceled. High +3 ".
What strikes me is that to become a little glutton with diesel. It also conveys the feelings driving me is not good when I travel with. On the mount is fine, but on long trips it is as if something was missing. The question is for the wise or that you have big wheels in TD4. There to play with the Transfer Boxes? add a shorter or longer? which can be put? Thanks in advance and I hope I expressed myself well. http://www.clublandrovertt.org/index.php?a...ype=avatar |
27th Jul 2013 10:23am |
Forgive this theme because I'm not.
Let's see if I understood well. Serial mounted 1.2:1 I recommend changing to 1.4:1 Is that correct??? http://www.clublandrovertt.org/index.php?a...ype=avatar |
27th Jul 2013 10:44am |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6092 |
Ci, correcto. Del factoria es 1.2:1, cambio a 1.4:1 para 35" neumaticos
Pero cambio los differentials es mas buena (mejor? mi espana es no muy buena!) Luismi.... ayudar!!! |
27th Jul 2013 11:07am |
Muchas gracias. Thank you very much. http://www.clublandrovertt.org/index.php?a...ype=avatar |
27th Jul 2013 11:12am |
Maybe it is better some groups 3.8. http://www.clublandrovertt.org/index.php?a...ype=avatar
28th Jul 2013 9:17am |
Luismi Member Since: 04 Nov 2010 Location: Cotswolds Posts: 178 |
Holy moly what's going on here
Morea at the end I put transfer 1:1 and 4,75 in a td5 with 33" so I ended 0.88 longer than a standard in High ratio, so not a big deal here, as we can say that its nearly the same. But in low ratio its where it rocks as mi first gear low ratio its much shorter that the first gear of a puma even with the 5.443:1 of the first gear of the MT82. In your case if your intention its to go back to the original ratio with your 35" I believe you have two options A- as the Diesel Jim already mention install the 1.4 transfer and then you will be just 3.03 % shorter than standard so pretty close. B- install the 4,12:1 that you may be 2.99% shorter than standard, I believe KAM still doing the 4.11, in that case will be just 2.75% shorter. if you go for the 3.8 you may be 5,18% longer than standard HTH let me know otherwise |
13th Jan 2014 10:51pm |
