![]() | Home > Td5 > TD5 is Jerky Jumpy when in Low Box - Really irritating |
Good afternoon Defenderites, I am in need of the collective brain today...
![]() I had the opportunity to do a bit of green laning over the weekend and mighty fine it was too, however whilst in low box the vehicle was jerking, jumping, shunting (all those words would describe the feeling) especially at lower RPMs. I have not come across this before and am at a loss as to where to start... Things that have happened recently: 1) Stalling when clutch pedal is depressed, then not starting again afterwards. This was tracked down to the Clutch sensor on top of the master cylinder. All worked fine afterwards until it happened again in Gibraltar on my Wedding day back in May, thankfully disconnecting the sensor at the plug allows you to continue. A week or so later I connected the senor back up again and all seemed OK. Replaced with non genuine sensor 2) I have fitted a recon'd transfer box recently as my previous one had a chronic drooling problem... 3) Injector loom replaced (not genuine) 4k miles ago when I serviced the 110. 4) MAF replaced with genuine LR MAF at last service. 5) Whilst crossing the Pyrenees the clutch biting point became lower and lower. I re-bled the system and it returned to almost normal. Fluid that came out was very black... I am fairly sure that might be evidence of the seals beginning to fail within the cylinders Vehicle: 2002 Defender 110 with 144k miles on the clock, original clutch and fly still going. Any help in narrowing this most irritating issue down would be great ![]() |
