Home > Maintenance & Modifications > Replacement windscreen hinges
Page 2 of 2 <12
Litch
Genuine ones seem to corrode regardless of how well the paint is put on.
Gave up on them and now have the BP anodised ones, nicely made and hopefully they will look good long into the future. ONE LIFE, GET IT!
Post #251967 17th Jul 2013 7:19pm
ZeDefender
I bought black anodised stainless Croytec ones (beautiful quality) and will try to convince the dealer to fit them when the windscreen gets replaced under warranty...
John Croydon seems a first class bloke and I think he can anodise in different colours (but don't quote me). Tell someone you love them today because life is short.
Post #252057 18th Jul 2013 6:01am
RFT
United Kingdom 2010 Defender 130 Puma 2.4 HCPU Zermatt Silver
Mine were replaced under warranty by Hillendale at 2yrs 364day old
They are peeped, primed and sprayed by their approved local body shop and by the look of the paint job they will out live the original factory fitted ones. 130 Puma HCPU with an Artica 240LR Demountable Camper
Post #252311 18th Jul 2013 10:57pm
Alex1976
I have OX4x4 hinges and windscreen blocks and they are great. Been on a year now and no problems. I sprayed them satin black as I don't like the shiny stainless bling look.
What were the issues with OX hinges?
Post #252474 19th Jul 2013 6:18pm
K9F
This is a direct cut and paste from the E-Bay advert for OX4x4 door hinges....
"........TDCI hinges have a slightly larger foot print. This will not cause an installation problem but may leave a "tidemark" if the paint is faded."
On the Puma when you remove the original hinges there is no topcoat of paint at all just primer, as the vehicle is sprayed with the hinges already fitted. Never mind about 'if the paint is faded'...in the case of the TDCI there ain't no paint to fade. A tidemark of primer was not the look I myself was after. I did contact them and suggest they make the footprint the same size to attract more purchasers perhaps? If you go through life with your head in the sand....all people will see is an ar5e!!
Post #252515 19th Jul 2013 11:28pm
I checked both my 07 and 10 pumas, they have paint behind the windscreen blocks and door hinges. if they spray them with the hinges on, to they mask the door hinge bolts ?
Post #252518 20th Jul 2013 6:48am
K9F
Did you take the hinges off to check? I can only speak from experience on the actual swap out. On mine on initial inspection behind the hinge point it does indeed look like the vehicle is sprayed, this is just from overspray it's not until removal you discover the fact that it's not. Under the windscreen hinge blocks it was indeed sprayed as you stated.
Your Ice has different colour hinges to the body so who knows the process on that vehicle? As for the bolts WGAF? It could be the hinges are 'gripper pinned' on for the spraying process, masked off or temporary bolts fitted until the doors go on, drop Mike@landrover a line if it really concerns you that much.
Cool If you go through life with your head in the sand....all people will see is an ar5e!!
Post #252535 20th Jul 2013 8:36am
Martin
Site Admin
Defenders are not sprayed as a built vehicle, the panels are attached to a dolly which goes through the paint shop. I don't know if the "hinges" are assembled to the screen or bulkhead when painted though.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #252538 20th Jul 2013 9:01am
K9F
Martin,
Don't think the windscreen hinges are fitted to either as BPman stated there is a normal paint finish under the screen ones. It's the door ones that appear to be already fitted prior to the spraying process on certain vehicles? If you go through life with your head in the sand....all people will see is an ar5e!!
Post #252542 20th Jul 2013 9:15am
Page 2 of 2 <12
