Home > Puma (Tdci) > Anyone had this?
RED-DOT
Anyone had this?
Got a creak/crack fron near the middle between drivers side but only in dry weather??? 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
Post #251073 13th Jul 2013 12:09pm
landybehr
sorry, not sure where exactly the crack is you refer to
(havenīt seen any crack on my 1year old Puma anywhere. But I turned to not looking too closely. Too many witness of the §%§##-build quality if I did Smile This way I sleep better).
Post #251175 14th Jul 2013 8:51am
ibexman
Probably a trailing arm bush talking to you Whistle
Post #251176 14th Jul 2013 9:01am
RED-DOT
I suspected that to be honest. Can a replacement be fitted? 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
Post #251180 14th Jul 2013 9:40am
mjj160
I have just had a similar noise on my 11 plate, it turned out to be a loose bolt that keeps the drivers side floor down, tightened up and all quiet again, hope your problem is as easy to sort out.
Post #251297 14th Jul 2013 7:47pm
LoveB
2013 Defender 110 Puma 2.2 SW Orkney Grey
Where did you locate the scew for the drivers side floor? I have 3 annoying me right now.
1 i know is the passenger side seat. its loose and moving about. Need to tighten it down.
2. is the dash. The steering column isnt on straight (aren't they all) and the left side is pressing up on the dash and causing a creak.
3.i have a feeling it could be the bolt on the floor.
Post #251646 16th Jul 2013 9:13am
mjj160
The bolt I needed to tighten was on the floor below the handbrake, just needed to remove carpet and then get someone to hold the nut from underneath the vehicle while tightening up from cab, if you have loose bolts suggest you tighten them all first before looking elsewhere, as noises on defenders can be misleading and sometimes difficult to pinpoint.
Mike
Post #251649 16th Jul 2013 9:32am
