Home > Maintenance & Modifications > Puma Headlamps |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20487 |
Have you tried them already by just plugging them in? No Guts, No Glory.
12th Jul 2013 3:29pm |
Swollock Member Since: 16 Mar 2013 Location: Wellingborough Northants Posts: 262 |
Been looking at Angel Eye myself but was waiting till Billing, I would suggest that you just pick up the feed wire to the original side lights and use a scotch lock, better still a heat shrink in line crimp, my preferred method, then the Angel Eye LEDs should come on with side lights only.
Tony 2008 Defender 110 XS CSW Volvo S60 T8 Triumph 1200 Rally Explorer G0UBX |
12th Jul 2013 3:35pm |
monco Member Since: 12 Jul 2013 Location: Channel Islands Posts: 3 |
No i haven't tried them yet but i believe that i must cut into the sidelight loom to connect with sidelights. Will be looking at it this weekend.
12th Jul 2013 3:38pm |
All the same I would recommend you do try them first. My headlights come on with sidelights all be it dipped (Lower power than dipped) if that makes sense. This happened IIRC when I changed bulbs.
Either way I would just try it and you never know you might not need to connect to the sidelight at all! No Guts, No Glory. 🇬🇧🏴🏴🏴🇮🇪🇺🇸⛽️🛢️⚙️🧰💪 |
12th Jul 2013 3:46pm |
Thanks Guys for all your help, will look at it this weekend and let u know.
12th Jul 2013 4:15pm |
On my Puma I get side lights only no dim dip on the headlamp unlike the 300Tdi that I have sold.? 2008 Defender 110 XS CSW
13th Jul 2013 7:24am |
Killer90 Site Sponsor Member Since: 09 Oct 2011 Location: Hertfordshire Posts: 6478 |
You'll prob have to take a feed off the sidelight wire As Steve said try before hand just incase CSK Automotive
www.cskautomotive.co.uk Like us on Facebook - www.facebook.com/csklr Follow us on Instagram - @cskautomotive |
13th Jul 2013 7:35am |
