Home > Maintenance & Modifications > Power Upgrade
Page 2 of 2 <12
mse
As pete said they really dont like warranty claims when a map is done - as a firend found out; but also if you dont tell them they dont know Wink
The other thing with warranty and land rover is the arguement of what is a fit for purpose. EG: a roof rack designed to fit the defender, by a reputable brand, in a way that land rover would have their own, should be the same as genuine one - unless they state NO aftermarket kit must be fitted.
To link this to your example, i seem to recall that there is a specific NO to remaps.
But remember there will always be the fit for purpose & reasonable use arguement to complicate matters Big Cry Mike
Post #2507 21st Jun 2008 1:01pm
bell-auto-services
Good points MSE i must admit that is food for thaught.
Regards Pete
Post #2508 21st Jun 2008 1:20pm
Nidge
Ireland 2009 Defender 110 Puma 2.4 HCPU Cairns Blue
bell-auto-services wrote:
How long did it take for your Autologic map to cause you problems ?
Was it problematic as soon as it was programmed or did it develop after some driving time.
Im just cusious to hear about all problems on this new model of car, im getting a bit info geeky over them lol
Regards Pete
Was only in about a week. To be fair to the guy who installed it he did alot of leg work for me to get to the cause of the problem . I am now led to believe, that Autologic tune was not the problem but the Common Rail System. Was just more obvious when the tune went in. Pete have you come across this in any of the vehicles you have tuned ?
Having said that the engine warning light has not come on since the tune was removed !!
Have to try and convince my local dealer now that there is something up now as its only noticeable now and again .
Nidge
Post #2509 21st Jun 2008 3:33pm
bell-auto-services
Ive seen many problems on this car even in standard form.
All sorts of problems from injector pump calibration missing to loss of injector codes.
You may just have been unlucky with the generic type tune of your car and itjust did not like it for some reason.
If your ever over in the UK in my part of the counrty for a few days ill install my map and give you a sample test to see if we can find the answer to your particular problem.
Regards Pete
Post #2510 21st Jun 2008 4:21pm
Nidge
Im just curious to hear about all problems on this new model of car, im getting a bit info geeky over them lol
Regards Pete
Pete,
Car back at the Dealer for warranty work , they say my running problems were as a result of a faulty fuel switch.
So reckon that was the cause of problems I was having with the Autologic Tune. To be fair to Autologic they did suggest that this might be the case.
Hope to reinstall the tune now and I will be on to you for EGR blanking plate and decat exhaust .
Nidge
Post #2807 18th Jul 2008 8:32am
jst
Bogblaster wrote:
I have the de-cat exhaust and the middle box replacement straight through pipe on mine and it goes so much better than standard.
Bogblaster - is your vehicle running std tune or was it when you fitted the de-cat pipe and straight through mid?
just wondering if its worth doing these mods without a retune.
My td5 went alot better with the straight through mid pipe and no cat but it was chipped and most people just seemed to report more noise and no power change with a straight through and no chip. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #6883 4th Feb 2009 7:25pm
Bogblaster
United Kingdom 2016 Defender 90 Puma 2.2 Adventure Corris Grey
My 90 has been tuned since the 10th day of ownership! Started with a Autologic tune (they trialled with mine) but the throttle response was a bit dicky, they have sorted it out now. Then Allisport put a bigger intercooler on (I tow a lot) and the Autologic tune didnt seem as good, so Andy at allisport put his tune on for a trial, I personally preferred it, then came the de-cat and the middle box out and Andy put on another tune (Allisport use BAS remaps) and it had the speed limiter removed as well. Have stuck with that since LRW at Eastnor last summer.
The final Autolgic tune to my mind was a bit too raucous, I reckon if I had kept it on I'd have been racing GTI's away from the lights!
So, in answer to your question, no, but I understand that a de-cat exhaust will improve grunt. Pete is your man.
BB 2019 MY Disco 5 HSE Lux
Audi A4 Avant 3.0L TDI Quattro - WOW
2016 90 Adventure
Post #6894 4th Feb 2009 11:23pm
jst
cheers BB Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #6904 5th Feb 2009 9:08am
jst
Pete
what sort of gains would you expect with a remap on the TDCi? and whats the cost. i had a look on your site and found the LR remaps listed they seemed to then be linked to further information but nothing came up when i clicked on them. Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #7005 7th Feb 2009 6:58pm
bell-auto-services
HI
Sorry for the slow reply,
Pleae find all info on this page
http://www.bellautoservices.co.uk/index.php?page=news
Title 07 Defender Re-map & Limiter
01/01/2008
Regards Pete
Post #7076 10th Feb 2009 12:34am
jst
excellent thanks Pete Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #7082 10th Feb 2009 10:19am
Page 2 of 2 <12
