Home > Maintenance & Modifications > How do i get the standard bumper off?
Icelandy
England 1985 Defender 110 Other PU Stornoway Grey
Do i have to take the front grill off in order to get some room to access the bolts fixing the front bumper?
Urgent assistance in how to do this is required as i have got someone coming to pick it up.
Thanks
Steve If a job is worth doing....
Its worth doing well....
So get someone who knows what they are doing! Smile
Post #2492 20th Jun 2008 5:36pm
mse
Depends Rolling Eyes
If you have AC you will need to remove the AC cover if not the bolts come straight out Mike
Post #2493 20th Jun 2008 6:01pm
Verdone
Belgium 2007 Defender 90 Puma 2.4 HT Java Black
On a non airco defender u dont have too, on an airco maybe cause the grill is further up Question
Greetings Verdone
Post #2494 20th Jun 2008 6:01pm
Icelandy
Thanks for replying guys.
For future reference. You can get them off without removing anything on the air con model as there is a small gap in order to do this.
Thanks
Post #2497 20th Jun 2008 10:09pm
mse
Thanks
Steve
Having just (2 nights ago) but the genuine winch bumper on there was no way near the room with my aircon, so it would look like you had some luck (or build quality issues Razz )
(the instructions also say remove) Mike
Post #2499 21st Jun 2008 8:47am
Icelandy
At the bottom of the grill surround, above the bolts, there are gaps. I assumed that these were there in order to get the bolts through?? If a job is worth doing....
Post #2504 21st Jun 2008 11:51am
mse
No they didnt appear to be - also; although i used my ratched spanner on one bolt - you would never be able to get a normal socket in that gap, certainly something you should do to torque the winch bumper bolts (although i forgot to do this on the bumper bolts) Mike
Post #2505 21st Jun 2008 11:56am
Icelandy
You are right, you cant get a normal socket in there, but the ratchet spanner did the job. If a job is worth doing....
Post #2511 21st Jun 2008 3:48pm
