Home > Technical > TD5 ECU logic
taffrican
Wales 2002 Defender 90 Td5 HT Java Black
TD5 ECU logic
Morning peeps.
Since I recently discovered the TD5 is not OBDII compliant can anyone explain what language the TD5 ECU software is so I don't get caught out again (after scangauge slip up Big Cry )
Thumbs Up
cheers Optimists say the glass is half full..
Pessimists say the glass is half empty..
Engineers say the glass is twice the size it needs to be!
Post #249912 8th Jul 2013 8:55am
I'm not sure that it's a 'language' as such. It'll just be Land Rovers (or their ecu sub-contractors) proprietary software.
You'll need something a bit more sophisticated than a standard fault reader to interrogate it, such as a Nanocom.
Meeting the ODBII standard for diagnostics only became a requirement for Land Rover sized vehicles from 2005. Darren
Post #249916 8th Jul 2013 9:06am
