![]() | Home > Td5 > Salisbury axle |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6124 ![]() ![]() ![]() |
No, the salisbury isn't quite the same as a normal rover diff.
To adjust the backlash you need to remove the rear cover, unbolt the bearing caps, use a compressor frame thing to slightly squeeze the casing to release the diff unit. then shim it up, refit, measure, remove, re-adjust etc etc until the correct backlash is achieved. quite a faff. |
tazmarkuk Member Since: 24 Jan 2012 Location: Birmingham Posts: 134 ![]() ![]() ![]() |
Thanks Diesel Jim,
Looks like I need to sort out specialist to do the job |
It's do-able at home; usually when the diff/casing gets worn, then the diff assy will come out with a couple of pry bars.
Obviously to refit it perfectly would need the use of a spreader or compressor, but a friend and I did my axle (when I fitted an ARB locker) with a huge G clamp he had. To fit the locker it was in fact easier just to remove the whole axle, access was waaay better then. |
