![]() | Home > Puma (Tdci) > BONNET HINGE RUBBER INSERTS |
zs1sam Member Since: 21 Jun 2013 Location: Cape Town Posts: 30 ![]() ![]() ![]() |
Noticed a loud knocking noise coming from the dash are especially when on corrugated roads. I've traced the source to excessive play on the bonnet hinges. It looks as if the rubber / plastic insert arount the hinge shaft has moved or is worn. Any tips / ideas how to replace or modify?
Sam 2011 110 Puma 2.4 |
Years ago on my old 90 I took the bonnet off(that cured it!) and when I put it back I had cut some thin inner tube into strips, used pushbike tubes, and inserted them between the different components to cushion the noise.
Thanks to both of you for the advice.
Sam |
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3657 ![]() ![]() ![]() |
better still buy some NAK hinges off Leeds or directly and everything is much better DEFENDER 90 TDCI XS,
