Home > Wheels & Tyres > Standard Tyres: what pressure?
Naks
Hi all
What tyre pressures do you guys run on an unladen 90 running stock standard tyres?
The manual says F/R: 2.1/2.6, but 2.1 at the front seems too low to me considering the weight of the engine, and 2.6 at the back seems too high?
I am tending towards F/R: 2.3/2.5 - what do you guys think?
Post #24752 21st Feb 2010 9:06am
jlerra
Gibraltar 2007 Defender 90 Puma 2.4 XS CSW Java Black
Tyre Pressures
Hia,
Stick to the manual directives - the tyre pressure have been worked out specifically for the tyre specification and the laden weight of the vehicle with the exception of driving in sand when they have to be deflated for grip then reinflated for road use.
If you don't keep to the spec in the manual you stand the chance of rapid tyre wear!
Tra-la-lu
'El Pepe Flamenco' Thumbs Up JLS
'El Pepe Flamenco'
Post #24774 21st Feb 2010 11:40am
ralton
South Africa 2007 Defender 90 Puma 2.4 SW Zermatt Silver
I run mine at 1.9-2.0 all-round. I find it a smoother ride, not too soft, just right...
Also, i haven't noticed any uneven wear after the 65000km at that pressure.
Post #24779 21st Feb 2010 2:13pm
Naks
Thanks guys
on an unrelated note, everytime I brake, the puma pulls sharply to the left. There is less resistance in the steering wheel when turning left than when turning right. and the steering wheel's centre is to the left by about 10-20 degrees when going straight.
What could be the issue there?
Post #24781 21st Feb 2010 2:25pm
austen
Australia 2008 Defender 110 Puma 2.4 SW Stornoway Grey
I too, find it difficult to run the fronts so soft. I run mine at 38/44, but the dealer always resets them to 42/42!
Austen. Rover 12 1935
Rover 20 1940
Rover 100 1960
Defender TDC1 2008
FL2 TD4 2008
Post #24813 22nd Feb 2010 6:18am
o4dn
France 2009 Defender 90 Puma 2.4 SW Alaska White
Re: Standard Tyres: what pressure?
Naks wrote:
Hi all
Funny you mention this, after a few months driving my car I decided this weekend to check the tyres pressure and what I found is quite surprising to say the least. Apparently, from factory (or at least from delivery) the tyres pressure was 3.5/3.6 bar F/R, ie way too much compared to what the manual says!
I deflated to 2.1/2.6 as per the instructions and get a much smoother ride. Why those tyres were inflated to that level is beyond me.
Post #24824 22nd Feb 2010 9:18am
Naks
No ways, that's what I found as well, spent 15 minutes just deflating them to the correct pressures!
And the spare tyre was inflated to over 4.2!!! No wonder we couldn't fit the spare wheel cover at the dealership Rolling Eyes
Post #24825 22nd Feb 2010 9:24am
Niel
South Africa 2009 Defender 110 Puma 2.4 SW Alpine White
rolton, i also had mine on 2 bar(when i received the defender it was over 3bar) but then at about 8k i did a 5way tire ratation and the guys at the tyre place showed me some signs of flat spots starting?? so now i am up to 2.4 bar all round Puma 110 sw White
No extras yet.
Post #24836 22nd Feb 2010 12:28pm
Eduardo
Hi there
According to the manual should be 2 bars (30 psi) in front and 3.1 bars (45 psi) in the rear
With standard tires I use in the front the correct one, but in the rear I use 2.4 (35 psi). Less than specify the manual, but with more pressure the truck get very bumpy, in special without load.
Cheers Eduardo
Post #24837 22nd Feb 2010 12:39pm
Naks
erm, pasted from the manual I received from LR, and I don't see the figures you are quoting:
Post #24838 22nd Feb 2010 12:44pm
Eduardo
Embarassed Embarassed Embarassed
That was for the 110 - sorry Eduardo
Post #24839 22nd Feb 2010 12:46pm
ralton
Hi there - was that on your 110? (or on a 90?)
Post #24843 22nd Feb 2010 1:17pm
Niel
110 Puma 110 sw White
No extras yet.
Post #24845 22nd Feb 2010 1:19pm
alantd
United Kingdom 2007 Defender 110 Puma 2.4 XS CSW Tonga Green
I was running mine too high. Subjectively they looked to be properly inflated (the quoted manual figures looked too soft and saggy). After 5k, however, I was wearing the middles down and not the edges. When the car was serviced, the dealer knocked the pressures back to the quoted levels and it now drives a lot better Embarassed One that started out as a 2.4 TDCi 110 XS
+ New Defender 110 First Edition
Post #24919 23rd Feb 2010 9:51am
