![]() | Home > Technical > Front wings |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6139 ![]() ![]() ![]() |
puma
side wing: RH ASB710260 LH ASB710270 front panel RH ASW710140 LH ASW710150 Headlamp panel: RH ASW710120 LH ASW710130 Whole "top/front/headlight panel" RH ASB710200 LH ASB710210 Inner wing: RH AWJ710430 (minus sound insulation) AWJ710420 w/sound LH AWJ710460 (minus sound insulation) AWJ710470 w/sound Td5 sie wing: RH RTC6351 LH RTC6350 front panel RH ASW710140 LH ASW710150 (as per puma) Headlamp panel: RH ASW710120 LH ASW710130 (as per puma) Whole "top/front/headlight panel" RH ASB710200 LH ASB710210 (as per puma) Inner wing: RH AWJ710430 (minus sound insulation) LH AWJ710460 (minus sound insulation) As per puma Just seems to be the outer panel that has a different part number. Don't know what the physical difference is though... they seem to look the same. |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17615 ![]() ![]() ![]() |
Wow! Thank you, five star comprehensive answer!
The outer panel ironically is the one I most expected to be the same. |
No wories. I was playing with the new microcat last night anyway so it only took minutes.
For a laugh... the new 2014 RRS stripped 5.0 V8 engine, costs Ģ13600 ish... that's what I paid for my new 90 in 1992! |
Just in case anyone else is wondering what is the difference between an Td5 and Puma wing outer panel, further enquiries lead me to believe that the only difference is the shape and size of the ole for the indicator repeater lamp. On the Td5 it is a square-ish hole, and on the Puma it is a rectangular slot. Other than that there appears to be no difference between ASB710270 (Puma) and ASW710150 (Td5) on the n/s, and the equivalents on the o/s.
Hmmmm.... microcat shows the repeater lamp on the late Td5's to be the same as puma
Well, in that case I'm baffled!
landybehr Member Since: 17 Apr 2013 Location: -D- Posts: 173 ![]() |
my MY12 front panel has another hole underneath the headlamp. I have no idea what it is for. I wasnīt aware of it until I removed the plastic headlamp/indicator/position-light - surround. Itīs approximately 3-4cm big if my guess out of memory works well.
I havenīt heard the TD5 have such a hole. If all plastic is removed thereīs only the rectangular (ventilation) hole midway between indicator and position-lamp |
Interesting, but according to Microcat it is only the wing outer panel which is different - all the others are apparently the same!
The mystery deepens ... |
Ah, I believe (don't hold me to this) that this is for in built DRLs. (A trader at the Harrogate show told me this) An engine to TDi for! "Land Rover- Proudly turning drivers into mechanics since 1948" ![]() |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4796 ![]() ![]() ![]() |
TD5 and Puma side repeaters are definitely the same
![]() 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
